Ghis77
Wanted... 450 Smart Fortwo Key With Transmitter
55 posts in this topic
....but this was done during a SAM change, so I don't know if that makes the difference (probably not).
Thank's Mike
I will call the nearest dealer and tell them it could be done. And I found the procedures in Evilution.
The car has to be programmed to the keys, not the reverse!
Buy a Delphi DS150E and code your keys yourself. The Delphi can be sourced for as little as £30 if you keep looking.
All keys have to be done same time.  China key with electronics cost around £20.
could you take the time to explain this procedure please
ive never seen that option on my delphi ds150e
Can we do everything with that? Like have the clutch ajusted? The cruise control? The ABS system?
Do you have the original or a Alibaba copy?
If you succeed to do it, then you might have a customer... you are in Toronto?
I'll post details later once I get back home.
The Delphi can code keys on all Smart 450 with SAM and all Roadsters. Regrettably it can only adjust clutch on petrol 450s and Roadsters,  cannot do our Cdi.
Can do gear change learning on all petrol 450s, cannot do my 2002 Cdi with ZEE and unsure if it can do later 450 Cdis with SAM. Can also run ABS pump and operate ABS valves on later 450s although this has not worked on some 450s I have worked on including mine.  Reads airbag and instrumentation too.
Can also read hundreds of other makes of cars and trucks.
For cruise control activation you need Star which can be sourced for around £200 from China. TAN free coding setup is explained on Evilution.
Edited by tolsen
well that explains why i couldnt find the function then
it appears you are using some other program with the delphi instead of the delphi software that it came with?
there is no way to do it with the delphi software?
Würth WOW and Delphi can do exactly the same but Würth WOW has more info such as Autodata and a few blueprints.
i have wurth wow 5.00.12 installed and working
but it wont connect to my delphi ds150e
says something about firmware update when i try to read anything with the box connected to the car
could you take a minute please to explain to me (a computer idiot) how do i update firmware (im assuming update firmware means i need to update the box?) ..preferably with something that would allow the same ds150e to be used with the wow software and the delphi 2014 release 2 (2.14.2.2) software that i have on this computer
yeah i didnt notice that until after i purchased and installed it that it was 5.00.12 instead of the 5.00.8 that you posted
now that im invested a small amount into it id like to see it work instead using another version ...might just get a different snooper that is compatible with this instead of sharing the ds150e (dont really want to risk screwing it up with upgrade unless someone knows for sure it will work)
i never did get the delphi to work with wurth program so i bought a different snooper for wurth
..and it connect fine
,,,and managed to bugger up my only working key
when trying to enter programming mode i get a bar that builds up to 100% then a screen that says to turn off ignition and immobiliser symbol should remain flashing but it doesnt...it just goes out like normally turning off the key and then the snooper loses communications..if i wait without turning key off it does the same thing.,,loses communication
so just an update..i have no idea how i got it but obviously the last combination of guesses was successful so i can now confirm that wow wurth 5.00.8 can actually teach in the keys (2005 450 canadian version)
it took almost an hour but i managed to get 1 key working
maybe ill try again to get more keys on a day when my blood pressure is lower
On 08/08/2017 at 11:37 AM, tolsen said:
Here is key programming procedure when using Delphi with Wurth WOW:
Hi Tolsen,
I know this thread is old.
Is it possible to repost the key programming steps with Delphi again please?
You can PM me if you wish.
Much obliged, great posts from you.
Bobby
Hi to everyone,
I have the same problem that had LooseLugNuts. Trying to reprogramme the keyfob with Delphi or Wurth Wow:
" when trying to enter programming mode i get a bar that builds up to 100% then a screen that says to turn off ignition and immobiliser symbol should remain flashing but it doesnt...it just goes out like normally turning off the key and then the snooper loses communications..if i wait without turning key off it does the same thing.,,loses communication "
How to go on?
LooseLugNuts in the end how did you manage to do it? I tried already many times and just one time I pressed many times close and open while no key blinking on dash and although the procedure was not completed one keyfob now opens and closes the car but immobilizer still on and of course engine won't start .
Help please
Barry from Italy
Car is a Fortwo year 2004 petrol 700cc
Edited by Barry
errors
Barry, set up a STAR system to use for yourself......keys done in minutes.
Yep...I'm a dick...lol....I do not know how else to program keys......but it's dead simple with the STAR.  Again sorry.....
