Anrai
Battery Shutoff Switch
6 posts in this topic
I will be flat towing a 2008 passion behind a motorhome. I need to disconnect the battery while towing. Can anyone provide some guidance on a battery shutoff switch which can be installed so I don't have to keep removing the battery cable?
Edited by Anrai
Most cars are shipped to the dealers with a big kill switch on the battery ground which is then removed during PDI. Check with your dealership to see if they have a spare (they are usually sent back).
Here ya go, I knew I had one that I was going to use in a project at some point.
Part number A 450 545 00 08
Try your dealership. It's a smart part number but it's not a retail item. If they like you they may get one for you. It is designed to mount to the stock position of the block heater/auxiliary 110V connector in the front air dam, which then replaces it when the cars come off the trains.
