Lito
Battery replacement for 451
4 posts in this topic
Hello all,
I had the great luck to be away for six weeks, south of the equator :) Please don't hate me ;)
Anyway, after coming back to this -20 ºC and below weather, I was not surprised to see the (still original) battery in my car seemed to be discharged. Lights and radio worked but there was no way the engine would turn.
I plugged in a battery charger for about 3 hours, plus an electric heater to make sure temp in the cabin (and battery) were above 0 ºC. After that the car started fine and I drove it for about 30 clicks to make sure it got enough juice to start again later on.
All this said, it maybe time to change the battery and I had two questions:
1. Any recommendations on replacement battery (451)?
2. Is there a special procedure to replace the battery? (other than unplug old and plug new [such as radio codes, computer reset or such?])
Disconnect the negative first, and hook it up last.
I'm not 100% sure the 451 is the same, but you'll need the 4 digit radio code from the owners manual after you swap the battery. Otherwise you're good to go.
Thank you guys. It looks like the battery is OK (at least for now). At least now I know what to do when it is time to change it.
