Bessy
Affordable Wheel Spacers...interest needed.
66 posts in this topic
Through five harsh winters on our impossibly bad roads I've yet to have a single bolt "rattle loose". But whadoiknow?
The rattle loose thing I'm not so concerned about, but the tendency to over-torque the bolts will likely damage the anodizing or deform the threads in the aluminum causing corrosion or worse. Over-torquing is a risk because the torque specs for the wheels are based on the threads engage into a forged steel hub not billet aluminum that has a drastically lower yield strength. The forged steel also has a higher modulus of elasticity, thus creating greater spring pressure on the threads, thereby creating better grip before plastic deformation occurs.
Francesco, I'm glad your spacers are working for you; they are clearly adequate to the task, my point only is, that the 3 bolt through-hole configurations are not inferior.
How many more sets and at what dollar value would need to be spoken for to make this happen?
Just a note to Marc: don't bother offering a 5 mm option, it's likely less hassle to just get them from Eibach. I paid $30 U.S. For a set last week on Amazon.
Not that I have a problem buying stuff that's "made in the usa", but if I can get them from someone local, I'd prefer to support them.
If a $200 -$300 order was all that is needed to get some made, there is enough interest.
I'd do all four wheels at 15mm via the longer-bolts route if the price were decent.
A $1200 minimum order looks less likely to happen. I would bank roll it if I thought I could sell 20 or 30 extra pairs of spacers.
The cost is in the set up. Probably about 2 hours of set up. Cycle time would only be about 2- 3 minutes. Material is about $40/pair.
CAD - $180
Setup - $180
Cycle for 40 parts - $180
= $540/40 = $13.50 each
+ $20 material
= $33.50 each or $67.00/pair
+ wheel bolts @ $8.00 each x 6 = $48.00
Grand total = $115/pair
That's assuming $90/hr for labour and CNC time. Some shops will do it for $65/hr. Maybe I'll go pay a visit to a local mennonite shop.
Bulk pricing is the key, it will bring down the cost of material and the bolts. I'm sure we can get the material down to $15/pc and the bolts down $3 or $4 ea.
Then there's anodizing. It's $110 min order, and we could probably get a couple hundred done for that.
I would help bank roll this, and we could sell the remainder on eBay.
What is needed in the way of CAD drawings? I may be able to source that fairly cheap.
I will look into what deals can be found on M12 x 1.5 wheel bolts. Update bolts for $ 3-4 is no issue.
Edited by Huronlad
I've found there are lots of suitable reasonably priced wheel spacers out there.
http://www.ebay.co.uk/itm/Hubcentric-15mm-Alloy-Wheel-Spacers-For-VW-Touran-5x112-57-1-Pair-/361085934940?hash=item5412661d5c:g:-l0AAOSw7ThUfQ4Z
Cheap for me, only £12.50 each delivered. All I need do is drill another two holes to suit the 450 and perhaps another smaller countersunk hole to keep the spacer attached to the hub.
Those first ones look pretty decent. I think they still might need to be anodized.
Not if done properly. Not all anodizing companies were created equal. The company I use guarantees their coating for 20 years. And that's not just lip service. They have samples that have been outside fastened to various surfaces since the early 80's, and the anodizing is still intact with only a little fading. Compared this to many of their competitors, who show surface finish defects and significant fading within one year.
The coating, aluminum oxide, is an electrical resistor, thus preventing galvanic corrosion so long as the barrier remains intact.
Here's a pulley I had coated by them 15 years ago. It sat outside for nearly a decade.
Anodised or not, the spacers will still suffer galvanic corrosion.
^^^This.
The Eibach anodized spacers started corroding during the first winter I used them for the roadster fronts on the rear of my 450. They are just about kaput now after six winters, causing a wheel balance issue. I can flatten and even out the thickness of them easily enough so the wheels won't wobble, but there are significant chunks of material missing around the edges that have simply flaked off. My Nokians are about finished now after six winters, so if I decide to drive the car next winter again I'll need to source both a set of tires as well as new spacers.
