1JR1
What ODB tool do you use¿
22 posts in this topic
Looking to buy an ODB tool for my 450 Smart.
I want to:
- read / reset codes
- enable the tach
- Read / load new ECU map files
The Galletto seems to be popular but I'm not sure if I can enable the tach with it. Might be something that can only be done with a Star computer?
Thanks for all your feedback in advance.
I just purchase some software to load on a laptop from eBay it's called Advanced 2015 OBD2 Scanner scan Tool software + ECU Chiptuning Remaping for $47.00 US plus $5.00 shipping it's compatible with all car manufacture. I'll let you know how it work when I get it.
Larry
Also found I can put together a Star machine clone for around $400. Still a little steep for the few tasks I want to do. Still interested in anyone else in the lower Vancouver Island area that might want to share the cost of ownership on one.
Star machine, Scan Gauge, Galletto 1260, Even the VCDS can read generic codes
You can purchase a multiplexer and then download a VM profile that's already been setup. MHHAuto is where you can find all the information you'll need to put one together.
I bought one of Star machine full kits after doing a lot of research from various vendors. The Dell630 is understandably second hand, and seems old, and had be resprayed (painted) but is otherwise fully functional. The latest 2015.12 MB DAS/Xentry software was installed and everything seems to work OK right out of the box, which is exactly as stated.
http://www.obd365.com/wholesale/mb-sd-connect-compact-c4-star-diagnosis-plus-dell-d630.html
Cables, connectors and mux all appear to be pretty good quality, although the C4 didn’t have batteries installed (not sure you really need these anyway).
Wireless connection to the MB SD C4 seems to be intermittent – I got a few disconnects and crashes in Xentry (javaw.exe) on wireless, but on cable it has worked consistently well so far.
For people considering buying a kit like this for newer cars (e.g. New C Class), the only advice I can give is that the Xentry software on modern cars will only let you do tests – (i.e. No Adaptations or coding); everything requiring change will need Online SCN coding. It’s a great toolkit to have for diagnostics alone though.
And i had another ELM327 Bluetooth adapter which is useless.
I was also curious if anyone knew of a Star machine located on Vancouver Island?
Presumably other than the dealer?  By the way, I have found Three Point Motors to be very good with quickly diagnosing and repairing electrical issues at relatively low cost.
To answer thr thread title, a Delphi DS150E, which does engine, chassis, SRS and braking system codes.  It can also do stuff like clutch actuator alignment, although I've not used it for that myself.  About the only thing (I think) it can't do is program new parts that require TAN codes, although I'm very happy to be corrected on that if someone knows otherwise.
maybe only certain years?...i couldnt find any clutch functions in my software
I'm not 100% sure but I think SAM equipped 450s and later have the full functionality.  It's in the "clutch learning reset" menu, "learn engage/disengage point" IIRC.
Edited by Chopper
someone with decent communicative skills should make a dedicated how-to thread about the delphi 150...
it would be nice to have everything in one place listing what it can do to which smarts and of course how to activate/install the software
really cheap tool well worth the $40 to $50
i picked up one of those kwp things mentioned above too for remaps but never got around to trying it
I want to:
- enable the tach
I have HEARD that using the wrong type can bang the kilometers up on speedo 10,000km each time its plugged in I was wondering about that too.
STAR is the best way if you want to invest the money....seriously.  Research it here as there are many threads on it and also over at Evilution....
