Frostyfx
How to manually open soft top
14 posts in this topic
Hello,
Am I ever in a bind!
I put the soft top up without the roof rails! Now the top is stuck half way and will not open or close.
Any thoughts?
Thanks
It should detach from the B pillar if you press the release button. Putting the soft top up without the side bars in place isn't a problem, normally.
Do any of you have a picture of the 4mm bolt that is used to manually operate the soft top on a 2009 Smart  fortwo ? I have removed the plastic cover that is supposed to show the bolt but I can't find it. I'm so puzzled. I tried to open the top, it moved about 6 inches and stopped. It will not move. No blown fuse. I build racecars but this thing I know nothing about.
This is the one that is normally included with the convertibles.  (Came with mine anyway)
 Thank you. I have this tool Leadwing. Can't figure out where it goes. 3 of us looked with much gusto to no avail. Puzzled.
Edited by bigtars
Tolsen.... I read it twice. How many more times do you think I should read it?  My wife read it only once. Do you suggest that she read it again ? Oh,,,, My son read it once also.  Do you think I should have a neighbor read it a couple of times ? By the way, there is not one mention of a 4mm hex wrench in my manual. NOT ONE !. " Read your handbook" isn't help. I would think you could come up with a better answer If you knew one.
Edited by bigtars
I have looked all over the place for info and found nothing. Others say it has only one motor. WRONG !!  It has 2 motors. But I cannot find where I can rewind the top manually. I'm so puzzled.
maybe it isnt possible to do on a 451
youd think it would be in the handbook if it was..or on the internet
only mentions i can find are for the 450
it wont be a bolt
if it has a way it will probably be in the center of some round housing that appears to contain a winding gear and an electric motor attached///.....like a power window motor
where is the tool stored in the car?
i checked my 450 cabrio and i see 2 holes where the motors are but no tool in the battery styrofoam and no tool in the roof bar storage area of the tailgate
