Lito
2015 Bosh Highline system
7 posts in this topic
Hello all,
This coming Thursday I will be picking up my 2015 Passion https://www.inventory.mercedes-benz.ca/inventory/certified-used-2015-smart-fortwo-coupe-fortwo-rear-wheel-drive-2-door-coupe-wmeej3ba9fk800272
This car is so different from my trusty 2009 entry model, I will probably be learning quite a few tricks as I re-discover a Smart car.
Moonroof, seat warmers, assisted steering... Those are rather obvious, but the most intimidating is the Bosh Highline system (yes, I am an old f@rt) ;)
The first question is, given that it is a 2015, would the manual for the 2011 be the same? https://www.smartusa.com/resources/downloads/manuals/2011/high_line_radio_guide.pdf Do I need to even worry about all I've been reading re: updating firmware or the like?
Also, any advise on using an iPhone with the system?
If you'd like to point out other things I should know about this new (to me) car, PLEASE DO!
Thanks in advance :)
Check the firmware version once you get it and post it.   I'll check the version in ours (2014 ED) later this week.   I know we have the most up to date one because I asked the service folks to update it for the spring service.
The dealer should be able to run the update for you regardless.
Looks like my firmware is v12.23, which I believe is the latest, is I guess no update will be required.
Thank you!
Great. BTW, when running, I do hear a background buzzing sound. As if there is a fun in it or something. I did hit the eject button thinking someone might have left a CD/DVD in, but nothing came out. Is this common?
Are you sure that's not coming over the speakers?     Our unit doesn't make any sound when it is on (pretty much always), and definitely nothing when it is muted (press on the dial button).    The AM radio gets a lot of interference from overhead power transformers.   The screen motor makes small electric motor noises when the eject is pushed.   I think that's about it.
Thank you Blaine. I'll check. Next time I'm in the car I will record it with the phone and post it.
Cheers!
