smartnhappy
Tires & 450 Passion Rims
2 posts in this topic
I tried to search out answer and got a gazillion feedbacks, all quite confusing and tangential.
OEM tires on front 4” 2006 Passion rims (I think it’s a ‘stylelines’) are 145/65R/15
OEM tires on rear 5.5” 2006 Passion rims are 175/55R/15
Who makes and what are the tallest and widest tires that these rims will safely accommodate, and are you currently using them ???
Could really use a concensus-type answer.
Thanks.
Technically you should not run anything wider than the 145 on a 4" rim but running a 155/60R15 really should be okay.  5.5" could run a 195/50R15 on the rear.  OEM sizes are very limited for choices.  Evolution has a listing on the OE 450 alloy wheels and tire sizes that fit and will not rub.
You are not likely to find a softer front tire than the 145.  If you want a wider front tire you would need different wheels.
