Noel
turns over but wont start
23 posts in this topic
car turns over checked alternator (spins freely) replaced Ebox  no change checked egr it is clear no blockage, fuel pressure is good glow plugs not working (I have it in the garage 20c in there should start) tried to check compression but my compression tester wont fit down into glow plug hole. battery is fully charged and I set it to boost when trying to start motor spins a little faster on boost but no start!! I bought the car dead have no history on this car. I do have another smart cdi that was in accident that ran perfect that I can remove parts from. both cars are 2005 diesel cdi 90k on smashed car 115k on car that wont start. any help getting this car started would be great. wont start with starting fluid either
I don't have the correct adapter and gauge to accurately check the compression by removing the glow plugs (and those can be difficult to remove from a cold engine)
My method can be done using common tools. The fuel lines can be removed using a 14mm open ended wrench.
I then use a 13mm long socket and put it on the right side of the injector and move it side to side to loosen and then remove. I then clean the shafts with solvent and a lint free cloth. Clean the shafts of the injectors and place back.
Jack up right side of the car and remove the rear wheel. Using extensions and T18 socket you can turn the engine by hand.
You will need a second person to turn the engine or feel to see if the injectors push out when turning.
Relatively simple and can be done in about a half hour.
You will need new copper washers/fire seals from the dealer to reinstall. They are inexpensive.
This works for me.
If one of the cylinders lacks compression it won't start.
Good luck!
my nearest dealership is 300kms away
Here's my experience with no start. I did end up getting it fired up - post #67. I do have a diesel compression gauge that works on the little smart cars via the glow plugs that you're welcome to borrow if you're ever in the Edmonton area. Smart142's method is quick, and also requires minimal speciality tools. Give it a try 1st.
Good Luck!
Edited by stickman007
newer injectors installed,got the glow plugs working (control box). Devised a compression tester cylinder one (270) cylinder two (0) cylinder three (90) psi thinking in going to have to go deeper and remove the head and check the valves. Any other ideas before I drop the engine?
i like to put air into each cylinder while at top dead center and listen to exhaust and intake (and crankcase) to confirm diagnosis more before removal
if its a valve it should be very obvious
no time to check the out the heads so I got the convertible smart  on the road today to busy at work to check the heads maybe on days off at Christmas and thanks for the input about the valves
24 minutes ago, GetSmart said:
Copper washers can be rejuvenated by heating with torch if you can't get to dealership. It swells up the copper and compresses nicely as it is designed to
You can successfully anneal copper fire washers. Heat until red hot and quench in water.
spent some time on the car. pulled the motor removed the head. SURPRISE!! head was mashed piston 2 was mashed melted seized rings on piston  2 &3 lucky for me I have a replacement but the oil cooler had been knocked off So I changed out the bottom of the block with the oil cooler from the dead car onto the other motor.  have it all put together except heads torqued. Now to put the motor back in the car and see if it will live! hoping for a Christmas miracle. spent the day today looking for a T55 4 inches long to torque the head no such luck need to come up with a different plan to torque the heads. any ideas out there that would explain melted pistons seized rings there is metal built up on the head that was hitting on piston 2? I'm thinking gas was put in the tank so I'm going to drop the fuel tank empty it new diesel flush the lines.
I figure the owner before had to drill and tap a glow plug out cause I found shavings on the block on removal. got the mighty beast running to night runs like a top. so pleased the frankenstein engine runs still need to weld a few bolts on in the inner fender wells fix up the plastic that the brackets mount to on the rear put tires on and go for a test drive its been   so cold here that the convertible smart wont start so next project is circulating heater on the convertible. THANKS!! to everyone for the interest and input on this project
I have seen a stuck/leaking injector cause similar issues, might be worth making sure they are good before putting miles on the car.
car has  been running great gave it to my daughter to drive back and forth to college she called me today said tempature is climbing to 120 but no heat in car im thinking air locked as the resivior is at max but no heat in car any other ideas?
Wait until cold enough so you won’t get hurt. Then remove expansion bottle cap and lift temperature sensor at top of thermostat to bleed cooling system. Top up as required.
Tie twine to clip that holds sensor in place before removing. Impossible to retrieve if lost.
My clip has a long nylon tie wrap permanently attached. Eye of some tie wraps are a perfect fit onto clip.
I guess you may have a coolant leak if someone has not recently touched cooling system. Therefore advisable to perhaps start looking for leaks and carry out pressure test.
Not uncommon is leaking tunnel pipes caused by corrosion and vibration and leaks due to mechanics fitting standard hose clips and over tightening them making radiator or tunnel pipes hose barbs collapse.
