smart142
Disassembly of engine
1 post in this topic
It's been years since I swapped out an engine or disassembled one.
I wanted to clean up the shop and had an old engine on a pallet. It came from my wifes cdi that had been rear ended and written off. I parted out the car and kept the engine.
Main damage was to passenger side rear.
I didn't have an engine hoist so I improvised and used my shop hoist - worked out well because I was able to change heights to make it easier to work.
Closer examination showed that the alternator had been damaged, motor mount twisted , and water pump housing damaged.
So I removed the fuel pipes, injectors, fuel rail, wiring harness, starter motor, high pressure fuel pump, various sensors - all useable parts.
I was able tor remove the glow plugs so I decided to remove the cylinder head - might be useful if someone had broken off a glow plug in the head.
It was a good days work doing this but it was enjoyable and educational for me.
3 people like this
