dalplex
Wanted: 451 muffler
10 posts in this topic
Hi, looking for 451 muffler.
The joint between the flexpipe and muffler is leaking and it and it seems not easy to be replaced with universal flexpipe.
please advise the condition and cost.
thanks
Here are 2 examples of replacement flex pipes that should work as a replacement.
https://www.ebay.ca/itm/1-3-4-x-8-x-12-Flex-Pipe-Tube-Stainless-Steel-w-Neck/190611296392?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2055119.m1438.l2649
https://www.ebay.ca/itm/17510D-Exhaust-Flex-Pipe-Stainless-Steel-Double-Braid-1-75-1-3-4-x-10-Long/161466184762?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2055119.m1438.l2649
If a shop is telling you it can not be done, they are certainly not qualified to do the work.  Any place that can weld stainless should be able to replace the flex pipe.
Thanks.
If the connection has a little bit of straight pipe to clamp. Yes. It is fairly easy.
The problem is the elbow shape connection is so short, making it barely possible to play with.
I will try to put on some putty and tape first.
Stainless welding gear doesn't appear to be necessary, the muffler and OE flange will weld decently with a mild steel wire or stick.  Booneylander and I have both done this, click here for details.
Mig welded them together after failed by bronze.
Then realized the alignment on the flange was off and basically can not seal.
So, after fighting with rear flange bolt and putting back the rear panel for 2 hours end with square back to original.
I think a dealer part of 485 is right choice.
take it to a muffler shop and get them to weld it
find a muffler shop that isnt attached to a big corporate name....the franchised ones are usually just parts changers
if you ever come north visit steve at the muffler shop on the kingsway in sudbury..."the muffler shop" is the actual name of his place ..he's good at patching up weird stuff
Bought new assembly from dealer and installed in 2 hour.
The original one will be available for sale.
Hi guys, I may be in the same boat later this year, but am thinking of making my own system using a stepped glass pack design muffler and maybe using the cats or seeing if you could remove half of it, noise depending...I do not like loud exhaust systems any more, yep, I'm old!  But, after looking at the stock exhaust can I think if you catch it before it seperates fully you could make up a "U" shaped trough and semi pinch that over the pinched area of the muffler nd tig weld it and repair the stock muffler.....yes it's all theory so far but I will be looking into it in a few months. I also saw what's inside our mufflers, plenty of restrictions which if you were to either gut them a bit or install a freer flowing can you may notice a bit more get up and go??? Especially if you installed a freer flowing air filter such as a K/N..?    The engine is simply an air pump, so if you increase the intake you must increase the exhaust flow...and visa versa......simply opening up the exhaust won't necesariloy increase the over all flow if the restriction is in the intake side also.     It's a ballancing act and you also must worry about upsetting the tuning of the engine for the computer not to get effected to throw codes at you.    I am a sick modder and always looked for HP in all my other vehicles, but so far it's just to get it to run well with a 45HP deisel engine with my new to me smart....lol.  Christ even my 650cc KLR started with less and now has more than what this has...lol.  Went from 37 to 50 HP and cost me thousands to achieve it.....sure it's fun to search for it, but also not 100% worth what it takes to get it....lol...I'ts a sickness...so hopefully I don't go down the same rabbit hole  I usually go down.   Sorry to go on.....another issue I seem to have.
This thread was discussing the exhaust for the 451 (2008-2015) model.
The 450 cdi and 451 are sufficiently different that there are separate sections for both.
