stickman007
DIY "no-slam" Circuit?
30 posts in this topic
This is the proposed wiring schematic. The GPIO pins will not match the above programs (yet), but they will once I can merge the 2 programs together.
In addition, I'm going to try and 3D print some connectors in attempt to make a pigtail so everything will be plug and play.
Hardware prototype done! Software loaded...will plug it in to test. With the current setup, the module will be in the car near the SAM, and a 4-wire harness will be plugged into the window switch via an adaptor pigtail. The door grounding signal will be pulled from the SAM unit. No soldering or wire cutting.
Decided to hook up the module to Red Pxl today...nothing caught on fire...hahahaha!
But the board didn't work. The input signals weren't reading correctly and later was traced to a bad batch of relays. All 4 of my 5v relays were duds when bench testing them. I used relays to step down my voltage from 12v to 3.3v for sensing input. Didn't have any optoisolators or the proper resistors to make a voltage divider. Just made an order on Aliexpress...guess will update on progress in about a month when the stuff shows up?
Edited by stickman007
Still no sign of my Aliexpress order...they haven't even shipped anything yet. But, I did finish drawing my schematic and lined it up with my python code so here they are for those who want to try and put something together.
import RPi.GPIO as GPIO
import time
downIn = 11
upIn = 15
downOut = 12
upOut = 16
doorIn = 13
def setup():
    GPIO.setmode(GPIO.BOARD)
    GPIO.setup(downIn, GPIO.IN, pull_up_down=GPIO.PUD_UP)
    GPIO.setup(upIn, GPIO.IN, pull_up_down=GPIO.PUD_UP)
    GPIO.setup(downOut, GPIO.OUT)
    GPIO.setup(upOut, GPIO.OUT)
    GPIO.setup(doorIn, GPIO.IN, pull_up_down=GPIO.PUD_UP)
def one_touch():
    while True:
        if GPIO.input(downIn)==GPIO.HIGH:
            print('Window going down')
            start = time.time()
            time.sleep(0.2)
            while GPIO.input(downIn)==GPIO.HIGH:
                time.sleep(0.1)
                length = time.time() - start
            if length > 1:
                print('One-touch activated')
                GPIO.output(downOut, GPIO.HIGH)
                time.sleep(4)
                GPIO.output(downOut, GPIO.LOW)
        if GPIO.input(upIn)==GPIO.HIGH:
            print('Window going up')
            ustart = time.time()
            time.sleep(0.2)
            while GPIO.input(upIn)==GPIO.HIGH:
                time.sleep(0.1)
                ulength = time.time() - ustart
                if ulength >1:
                    GPIO.output(upOut, GPIO.HIGH)
                    time.sleep(4)
                    GPIO.output(upOut, GPIO.LOW)
        time.sleep(0.5)
def no_slam():
    while True:
        if GPIO.input(doorIn)==GPIO.LOW:
            print('Door is opened')
            time.sleep(1)
            GPIO.wait_for_edge(doorIn, GPIO.RISING)
            print('Door is closed')
            GPIO.out(upOut, GPIO.HIGH)
            time.sleep(1.5)
        time.sleep(1)
def destroy():
    GPIO.out(downOut, GPIO.LOW)
    GPIO.out(upOut, GPIO.LOW)
    GPIO.cleanup()
if __name__ == '__main__' :
    setup()
    try:
        one_touch()
        no_slam()
    except KeyboardInterrupt:
        destroy()
For those who don't want to type the whole thing, here's the python file.
NoSlam-OneTouch Program.py
