ChickenGeorge
Sam Internal Wiring for N11-3 Connector
2 posts in this topic
I am looking at by-passing the N11-3 connector as Pin 11 seems to have erratic connectivity issues.
I am hoping someone could point to where in the SAM I would terminate this to.
Thanks,
George
Remove the SAM, make note of where everything is plugged in including fuses!
- Open up the case (a few screw and plastic tabs)
- Be careful not to damage the ribbon as it is fragile
- Locate N11-3 and clean up the area with contact cleaner and or with a tooth brush
- Solder the wires you wish to bypass directly on the PCB
- Drill a hole at a convenient location
- Run the wire(s) through, and reassemble everything
- You could either solder the wires directly to the corresponding wires on the harness, or you can purchase pins/connectors to make your own (recommended).
SAM pinout and removal instructions can be also be found on either evilution or fq101 should u need more guidance.
Good reading before you start:
Edited by stickman007
