VonJuicyTitz
How to get air locks out of the system on this engine.
6 posts in this topic
Does anybody here knows where the thermostat is located on this engine or how I can vent the air out after a cooling change?
Help is much appreciated!
Your thermostat sits at top left corner of cylinder head hidden under the two fuel pipes and single vacuum pipe.
Ok. Thank you! I so glad I didn't have to disconnect all that to get to it..
I left the car overnight with the coolent cap open with the car tilted a bit to the back. And the coolent holder went from over max to under minimum over night and the air got out.
Hope my solution can help anybody who got the same engine/issue that I had when changing coolent.
You can also vacuum bleed but much easier to lift coolant temperature sensor. Then no need to buy vacuum bleed kit.
