stickman007
Chinese Oil Filter Adaptor
19 posts in this topic
My last Smart car had an oil filter adaptor imported from the UK and it was expensive. Decided to try a Chinese made one this time around. Ordered from Aliexpress under the brand VOLM. Took about a week to get here.
The fit was good - its close to the CV boot, but doesn't make contact. No leaks after driving for about 30min. I don't usually use FRAM filters, but this was the only one available from CT that's less than $20! FRAM PH3593A - a list can be found on evilution for the M20 thread. This was the biggest filter that I found from the list - trying to increase my oil capacity.
IMHO, it will contact by the looks of the pic when the shaft moves within it's range but pics aren't accurate....interesting though.
I am after a oil pan with plug, sick and tired of the mess of the sucker and also must have engine warn to get oil to travel easily.
Go to CTC buy a 1/2" fine thread nut and a short bolt with threads up to the head.
Got to the self help parts and see if they have an oil plug that fits the nut (older fords were 1/2" nf IIRC) or at least get a 1/2".
Take off your oil empty oil pan, easy job.
Drill 1/2" hole around the front edge passenger side of the pan.
Clean off the paint around the hole.
Stick the bolt through the hole from the inside out and hand tighten the nut on.
Now weld or braze the nut only to the pan.
Once cool seal using a coating of JB weld just to be sure.
Remove the bolt and if you want to paint the pan.
Put the pan back on the motor and if you found a pan plug put it in and tighten.
If you didn't find a pan plug put the plug casket onto the 1/2" bolt and use that as your drain plug.
Note doesn't work on aluminum unless you can weld it correctly.
I would but my pan is too badly rusted and dented...or it would be done by now...lol....so I'll spend huge I think for new pan with plug.....sniff sniff.
26 minutes ago, BWM said:
Take off your empty oil pan, easy job.
Not always easy!
On more than one occasion I've had the head of the E8 bolt snap off.
And sometimes difficult to break the sealant holding the pan on.
And it's messy because there is always some oil left in the pan and I always get some on me :rolleyes:
I have 2 bolts stripped and will require heat and convincing.....so it'll be an ugly job when I get to it...also the oil is thick and cold...so doubt if sucker will even move it....so it'll be getting a hole punched into the old pan if not one drilled nicely. lol
I could've sold you my extra! I ordered 2....hahaha
@Willys No contact...checked again today. My UK one was close too, but never had any issues - I did use a smaller filter in the past.
Edited by stickman007
Donaldson filters available from Finning will come in a nice long size and be relatively inexpensive.
Just doing some research here for M20 filters. I went on a WIX filter site and found a few long filters that MIGHT work. I'm really interested in increasing the oil capacity...not sure if it'll have any adverse effect.
PH3593A - 3.03" OD x 3.39" Length, gasket 2.13" OD and 2.42" OD
WIX M20x1.5 that are approx the OD of the FRAM filter that I used above:
51285 - 2.967" OD x 5.811" Length, gasket 2.37" ID and 2.74" OD
WL7433 - 3.03" OD x 3.35" Length, gasket 2.44" ID and 2.8" OD
WL7457 - 3.03" OD x 3.74" Length, gasket 2.44" and 2.79" OD
None of the WIX filters with gasket OD that was around 2.42" were over 3" in length
I'm thinking Wix WL7096. Cheap, anti drain valve, and they include the filters physical measurements so I can check prior to ordering that they'll fit.
Got my adaptor plate for £11, a huge saving, so very happy.  Hopefully it'll arrive as quickly as yours did.
Edited by Chopper
I used an adaptor from smann, fit perfectly and used an extension because of different sensors. the only mod. done was the stainless coupling, The one that came with the extension was too loose of a fit for my liking so I had one made to my specs.
Well, my adaptor arrived today, only 8 1/2 days after being ordered, which was most pleasing.  Went with the Mann oil filter in the end, which was a good balance between known excellent quality, and price.
I wonder, what do others think about increasing the cooling ability of this oil cooler...?    Does the stock cooler do an adequate job..?
The petrol, like what mine is, doesn't have an oil cooler at all.  That's why the extra 1/3 litre of oil that a canister filter holds will be a welcome addition.  It may be that over winter I go the aftermarket cooler route, if it looks like it'll be staying another year.
Oil filter has arrived. Went with the Mann 610/2 in the end.  Just need so oil and I'm good to go.
