Bebeto
Issue with my CD player
3 posts in this topic
Hi Everyone,
I’ve been having an issue with my CD player (CD changer) in my 2008 Smart ForTwo. The changer can normally hold 6 CDs. I had loaded 6 CDs into the player and for some reason the first 5 worked perfectly fine, they played and changed with no issue. For some reason I wasn’t able to play the 6th but all the rest of them worked just fine. They worked for about 2-3 days in total and then it all just completely failed. Now none of them play, they don’t spin and all you hear is an odd mechanical noise when you try to start them up. All of them are also now jammed inside. I’ve tried every little trick posted on YouTube but nothing seems to work. Does anyone have any advice or would you happen to have a good mechanic (Toronto) I could go talk to about my issue? Should I even bother repairing it?
Welcome to the club.  I have read of a few of the multi disc players failing.  Replacement would be the way to go.
I threw mine in the bin.  My solution was an aftermarket head unit and fascia adaptor.  I chose a head unit that reads MP3 CD's, so managed to fit 15 odd albums on the one disc.  Job done.
A head unit that can take a memory card or memory stick does a similar job.
