Focussmart
Wiper Blades Stay On
10 posts in this topic
wiper blades always staying on until engine is shut off how do I fix this?
Edited by Focussmart
What, you want them to fall off?  You're trying to remove them?  More precision would not go amiss.
First of all welcome to the club.
Please tell us a little more on what you are trying to accomplish.
I bet his issue is they never shut off unless the key is turned off...?
OK...what did I win...?
He said blades not motor.  I assume the same as you but you know what happens when we assume.
6 hours ago, Focussmart said:
Willys you are correct
OK, great....now what do I win...lol.
As stated above it has to be a switch issue allowing the constant power being sent to motor.  OR.... a shorted out rubbed through wire in the steering column maybe..?
What in the wiper motor tells it to stop in the park position (some type of micro switch or electronics)?  I suspect the wiring would have three wires to the motor 12v constant, 12v switched and a ground.  If the switched goes on and off with the wiper stalk then the problem in in the motor assembly.  As I have said before I’m no mechanic but that is how I would expect it to work.
