Paul
Ukrainian muffler
17 posts in this topic
Has anyone else tried one of the $200cdn mufflers out of the Ukraine? I've just gotten and installed one, and am quite impressed for the price. Quiet, and easy to install
Edited by Paul
I would be very much interested as well in any good quality aftermarket mufflers for the 450.
The previous owner bolted a straight pipe on mine and the rattling sound it makes when idling is all but enjoyable, especially for my neighbours next to the driveway.
Was considering this one https://www.ebay.ca/itm/Smart-Car-Exhaust-Muffler-for-SMART-Diesel-0-8-1998-2004-450-eco/263120125257?fits=Make%3ASmart&hash=item3d432e7d49:g:dggAAOSwxmJZ0x7v&vxp=mtr
but was not sure if it fits the diesel 450. Is there any difference in dimensions and mounting between the petrol and diesel mufflers?
That is probably the one Paul is talking about.  It is from the Ukraine and is about $200 Canadian.  It also says for diesel 450.
Keep in mind it is galvanized steel and probably won’t last like the original stainless muffler.
Hmmmm....that is simply a cheap can with a pipe welded to each end, maybe worth 1/3 of that price....I also bet it won't last 2 years......when you add the winter salt package to it....sorry to say. I also looked at one  and was very interested until I saw what type of muffler it was. IMHO, I think a repaired stock muffler would last you longer than this one will......but time will tell.  Fingers crossed.  Hopefully I'm wrong.
I removed my CAT and I do get a whiff of diesel if i sit at a light too long, but normally you are moving so all's good....to be honest, there is really nothing special in a stock can after you remove the CAT , that this muffler will have in it. It's just the outer case that keeps me away from buying one. The stock muffler is far superior to  this design imho. Just because of seeing them rot at the seams after a short time on the old American cars decades ago.  BUT, they are far cheaper than a new stock muffler....by far!  It'll cost you slightly more than this to get your rusted stock can re-welded.....so the choice is yours.   I hope we find out how long it actually does last, stay in touch Paul and give us the scoop.
Well, its been in for a few weeks, and on startup I get a bit of diesel smell, and its slightly noisier than stock, but Im happy with it. Bolted up easy and came with a bracket and strap. No indication of rust anywhere yet. I do have the option of getting a friend to put in a cat for me if I want. He owns an industrial exhaust manufacturing company. I'll see, maybe
Edited by Paul
My ukrainian muffler is on his way, I mean stuck in an airport somewhere, any tips on how to rust proof this cheap can to have it last a little longer? Can POR-15 work on galvanized steel?
Just my .02, Rustoleum makes a high temp coating.  The POR-15 site says " POR-15 does not adhere well to smooth, shiny surfaces, but will adhere well to those surfaces with the proper preparation."   Doesn't mention high temps.  :)
ive never really ever found anything that makes a muffler more rustproof other than making sure it gets used often and reaches proper temperature often
also make sure the drain hole is working
And facing in the correct direction....lol.
Just an update on this muffler.
After few hundred kms the bracket "tongue" that the muffler sits on snapped and left the muffler bouncing on the bracket top and heat shield behind it, producing a hellish rattling sound as you would expect.
Probably I've tightened the bolts too much but the thing is there is no damping in the whole mounting since it didn't come with a rubber bushing.
So if you're getting one of these, along with the rust proofing, do put a rubber somewhere between the muffler and the bracket, the vibrations from a 3cyl diesel especially at idle are too much for a rigid mounting.
Also, I didn't find any drain hole in the thing.
I fitted yesterday a 1999 Smart 450 petrol 0.6 muffler on my 2002 Smart Cabrio Cdi.
No cat in this muffler. Also no hole for Lambda sensor since no cat.
To make this muffler fit, all I had to do was cut inlet pipe, shorten it a wee bit and reweld pipe in place.  Obviously tack welded whilst on the car, then removed to complete weld.
Engine seems more powerful with this catless muffler. Sound is just the same as the original muffler.
Reason for replacing muffler was cat had rattled loose.
4 people like this
yeah, after a few monhs I noticed a rattle. seems the bracket has cracked. Just going to use a decent quality stainless clamp. Other than that it seems fine. A little smelly when sitting
the strap is what initially broke, so I put a hose clam around it, and that has been fine. The other day however, the bracket cracked, making a good rattle. I had some old conveyor belt lyiing around, so I wedged a small bit between the bracket and the muffler, and used the hoseclamp to secure it. So far, so good
