P51mustag
451 gear problem
5 posts in this topic
Hello smart fans I have a 2008 smart 451 and I have a strange fault when my abs sensor are connected at rear the car goes in gear then I only have to move 4 feet and it goes in to neutral when stop it gose back into gear it will skip gears as well so if I disconnect the rear abs it will go in to gear but only gose up and down the gears with tritron it will not do auto as it just stays in auto 1 I have a foxwell  and it says control module n1 5/6 sprint shift control module is faulty dose this mean that the ecu under seat has a fault can any body help please
Just a question have you checked reluctor rings to make sure they are not cracked or broken...?  Just to rule them out of the equation...?
