smartzuuk
15 years later... fully electric.... 2020 VW e-Golf
15 posts in this topic
So we took home a 2020 e-Golf on April 30th... maxed out the available incentives including a "scrap-it" voucher, and said good-bye to a Volvo C30....
Managed to find a "non-loaded" Comfortline with leatherette in a good colour.... was not interested in the Technology and Driver Assistance packages which would have added more than $5000 out the door for what I describe as a bunch of fluff.... fluff that looks like it could act up in the future, seeing as it is all sensors and bells and whistles, and not really anything physical, save for some ambient lights and a 1 inch bigger screen, lol
So $41,000 plus 12% tax on the top, less $5k federal rebate, less $3k provincial rebate, less $6k "scrap-it" = $32k out the door
Impressions 10 days later?
The car at 80% charge has a nice weather range of 230 kms, and charged at home on a Level II, you could quite easily get that range up 290 kms in a pinch if you were planning on a long day or a distant trip...
Anecdotally, we are easily able to get the European rated efficiency out of the car, which is 13.8 kWh/100 km, and I can eke out as low as 11.0
Heated seats use very little battery range! Heat, AC and heavy fan use obviously will eat up range. That said, even in winter, I predict 130 kms of useable range while charging the battery up to 80% from 30% remaining.... which seems to be the consensus on what to do the majority of the time on a Level II (home) charger to extend battery life expectancy
Car has an Eco and Eco+ mode which tame the throttle input, max speed and even restrict climate control in the case of Eco+
You can be engaged with the car using the shifter to select 4 stages of regenerative braking - great for everything from stop lights to long mountain highway descents...
Lots of free charging infrastructure available, even some BC Hydro Level III fast chargers. Most of the fast charging has a fee, deservedly so, but there are lots of places to get Level II juice without cost. We're only using free charging right now until we move in July and get a home charger installed...
Car has power, drives great, and being a Golf (ie: not designed as an electric car), it has personality that possibly is lacking in some of the austere EV specific models other makes have out.
True - the e-Golf is now done... but I think this will remain a classic EV for years to come, and VW will certainly do well with their next EV specific offerings if they hit the price point that "average joe" can relate to and make the move on.... The closest Tesla is many thousands more, with a ridiculous software limited range enforced on it... Kia is $7000 more at least... GM about the same... Nissan also, and you don't get the extra range in the Leaf without spending almost $15k more
250 km range from 110-0 and 130-180 range charging optimally and depending on weather is highly useable, and we're turning this into a shared car and putting most of the mileage onto it
At 200,000 kms, the car is but a $6500 cost overall factoring in the reduced operating costs and reduction in "fuel" expense - even maintenance is $3500 less over this timeframe by my pessimistic estimate - that's based on 30 DIY oil changes, one timing belt/water pump, a couple tune ups and other various items....
Thankfully, we have hydro-electric power in BC, and I hope they will introduce time of day billing, as these cars should charge during the night
Buying an electric is not going to save the planet or help climate change in any meaningful way, but I hope this helps the air quality in the Fraser Valley.... Like Mike T, I jokingly refer to these cars as "EEV's" / "elsewhere emission vehicles", and my opinion is largely unchanged if you're in a region that's burning coal to power them.... but since BC is not doing that....
Vin # begins with "WVW"... for better or for worse. I would NOT have wanted a Mexican VW though.... so it mattered to me.
Fire away!  lol
Cool! The Mk7 Golf is a really great looking car, and 230 km range is pretty decent. $32k is still a hefty chunk of change after all those incentives, though. But it's been a while since I've bought a car at all, so my perspective is probably skewed.
Looking forward to reading about your ongoing experience with it.
You would be $40,000 out the door with any other EV.... even despite that level of incentives... The absolutely disgraceful Tesla software limited range of 150 km base model you can only order in the store (not online) starts at $45,000 and you can't get Scrap It with it.... The Bolt EV and a coupe of the Hyundai/Kia products have better range, but will run you more $$$.
So I think for our first EV, VW, hit the sweet spot, in terms of range and price.
They say it costs $100 USD per kW for battery size, and if you are thinking life-cycle impact on the environment etc.... buying more battery than you need should be verboten. Rare earth elements, and mining, and all that.
Mazda's new MX-30 should be interesting, with a similar EV range as the e-Golf, but more than likely a rotary engine generator on board to turn it into a longer range vehicle.... we'll see what we end up with in Canada soon enough. That would be a vehilce type I would consider if we should need a second vehicle for anything more than occasional use, which as of late is not the case.
We've had our Leaf SV for over a year now and am still very happy with it.
Best thing about owning an EV model that's been around for ten years is, there's lot's
of batteries around to use as a replacement plus, there are now aftermarket companies
starting to produce them...
I hardly ever drive with the radio on as, I find the quietness so satisfying.
Edited by lebikerboy
Given what's happened in recent months, I'd be skeptical that Mazda has the resources to invest right now in a rotary range extender for the MX-30. Even bringing a new EV to market right now is going to be a challenge for Mazda.
This morning I was heading over to Vancouver's West Side to bike ride around the area plus UBC  to my amazement,
at the corner of Georgia and Denman there was a Tesla Model S on my left, a Telsa Model 3 on my right and A Kia Soul EV
next to him. Four Electric vehicles in a row! Times they are a changin'...:D
Hmm... I sure do see a lot of Tesla product on the roads... but Leaves and Bolts as well...... lol, couldn't resist
I would expect to be able to change out the battery in the VW if it bites to bullitt after 8 years
We are trying to operate it almost all of the time on Level II between 30% and 80%
Getting closer to 10,000 kms on the eGolf with zero issues. Except occasional brake noise - because they get used so lightly and get pretty dusty.... German build quality shines on this car. It's all the car one really needs, lol.
Range is proving itself to be reliably 150-180 useable kms operating between roughly 25% and 90% of battery charge, ie: from 230-240 kms down to around 50-60 remaining...
Read an article on incentives and net prices of the upcoming Rav4 Prime... Quebec sure is making gasoline obsolete!
Anyway, there was an interesting remark about the Prius Hybrid and how hybrids far surpass Tesla's in terms of net tailpipe GHG reductions when looked at based on the electric battery size.... ie: more hybrids on the road for the same amount of battery materials... I haven't dug into whatever might exist for the analysis backing this up, but it makes sense. Making a battery with 85kW or 125kW of potential storage "just to cure range anxiety" is pure silliness.... I can see where a 400 km rage vehicle makes a lot of sense (newer Leaf for example), but 200 ish is still going to meet 90% of daily users needs...
I can't see anyone making gasoline obsolete except within city limits maybe and that will be a massive maybe.....but that is just me.  I agree totally that most city dwellers can use a 200 km range vehicle easily for the rest of their days.   Rural folks can't, so making fuel obsolete is a crazy notion.....and I know you didn't mean completely doing so.....lol.
BUT I do see the usefullness of a 400 km vehicle even for us country bumpkins...lol.
Our next and last new car will most likely be a hybrid.
Other than the fact that there are two drive trains to worry about plus the normal ICE maintenance requirements and whenever the ICE is started...sorry it's a crock.
LOL, quick update..... So back in December, a used 2019 Hyundai Kona appeared on a Hyundai dealers lot with just 19,000 kms and a very convincing price.... I took the VW in, and made a deal the same day and drove home for less total cost than the difference would have been to get the Kona new as oppised to the eGolf..... the VW clearly was the better vehicle overall I must say, but even knowing that, the range of over 400 kms is well worth the extra out the door... The VW had 19,000 kms on it as well, so it was a real no brainer to swap... $8700 extra after tax. New, a Kona would have been roughly $3000 more than what I was now out of pocket in total....
Good weather is now on the menu in BC, and a 90% charge is giving almost 450 km range... 80% just about 400!
I can use as little as 13 kWh/100 km as per the vehicle estimate
The VW ID.4 will kick the snot out of the Kona once it is actually available.... but until then.....
Already at 36,000 km+ and going to add 20,000 or more this year before winter arrives I think
I keep an eye open for smart electrics... saw one once for $8000 which would be an ok deal I think.... although such limited range is an issue, even for a daily commute here in the valley
The VW was never intended to be a long range vehicle... we simply upgraded for the longer range after our expectations with an EV were exceeded
I have no qualms about taking the Kona cross country at this time.... probably will do a trip to Manitoba this spring at least
I don't think we will every buy another new car now that Peugeot is bailing on Canada and USA again.....actually I didn't REALLY need one anyway.  The Benz has only 306K km and should be good for 500K km easy.  Scrapping usable reasonably economical car like this one before their service life is over is super dumb anyway.
