simon28
Intercooler fan delete winter time
6 posts in this topic
Quick question
My IC fan assembly (fan motor+shroud) is shaking a lot while idleling. Make an annoying noise. When I touch the fan, the noise goes away
Since I don't have EGR valve, so no hot exhaust gas going back into the intake, can I remove the IC fan assembly during winter time?
Thanks
Simon
mine would squeal once in a while ...so i drilled a small hole right at the center where the rear shaft bushing is and occasionally gave it a small spray of oil
just a suggestion that might fix your noise issue for summertime if your noise is due to a bad bushing
The noise is not coming from the fan itself, its the fan assebly (fan+shroud) that shake and rattle against the IC. Now everything is removed, no more rattling noise.. lol
I have rebuilt the electric motor this summer. Clean the brushs and re-lube the ball type bearing at both end. Tig welded the motor cap to the motor metal body. Fan is now working great.
I take note of your idea. Drilling a small hole in the motor, It's a brilliant idea
Thanks for your reply
We had a discussion about this a few years back. Disabling the fan and blocking off the inter cooler in the Canadian winter will warm up the engine and heater faster.
OR ....you can simply block off 3/4's of the front radiator....simple and it works.  Just remember to remove it in the spring.   The biggest issue in our winters is ripping off the plastic inter cooler plastic scoop if you run into deep snow possibly...?   It is the lowest thing hanging down...?
