Jakez
handbrake light constantly on issue
5 posts in this topic
Hi looking for some advice please
I have a smart four two 451 model 2010
Handbrake light is constantly on and beeping when released
I have change handbrake switch made no difference. I have also scanned the car with an ob2 scanner no faults come up car drives normally.
Any advice on what it could be many thanks
Then I think you need Mercedes diagnostics probably if there is nothing obvious.
Look about for a private Smart specialist if you can or Mercedes specialist if you can't find a Smart one.
Do not take it to a Mercedes garage, they will have your shirt off your back.
check electrical circuit of fluid level sensor...make sure float is working if it uses a float system
if thats not a problem then id suggest accessing a scantool that can go into the various body control and abs modules to read actual live data of switches and sensors to narrow it down
