RoySkyBell
What is that Part Number??
336 posts in this topic
can anybody tell me what do you call this part?0000920v009 dnw12418(i may have my digits wrong)
0012172V001000000 Brake Shoe CA$146.45 list. N.B.: This is a complete kit with everything except wheel cylinders and drums; all new springs, pins and adjusters.
Does anybody have the part number for the BRABUS Monoblock A 16" wheels? Should be something like "A13-656-[offset]" and "A13-556-[offset]" but I'm not sure.
End caps for 450 factory luggage cover rods:0007905V001C22A00$1.07 each. These are now made of a more resilient material, not the tear-able rubber that my 2005 came with.
For those who would like to look up part numbers directly from VIN using MB's EPC, this link is handy (I posted something similar elsewhere on this forum, but not sure where) But this one works well and this is probably where it should be , or in sticky
http://www.auto-parts.spb.ru/cat/cats/m.my...p;client=dr2000
Choose smart, not car! Also works for other Mercedes.
Rear Window Glass Support Lift Strut
I found it very difficult or impossible to locate a factory replacement for the rear window support lift struts, but there is an inexpensive generic aftermarket replacement that fits and works perfectly! It is the Strong Arm part # 4420. about 12" long and 30 lbs thrust. Available at Advanced Auto Parts and on line.
credit: mineralfarmer
That was a lot of work...thanks.A few numbers to add.A 642 092 05 01 list $61.90 Sept 2011 Fuel filter without water sensor attached. This part looks different and is shorter than the combined unit but the sensor part number is the same for both the shorter and longer one.000 4984 V000 000000 list $1.06 Jan 2011 undercarriage screw part numbers are only for the 2 longer screws that mate to the yellow clips.001 991 39 70 list $.89 Jan 2011 yellow clip, one used on each side of plastic belly panA 160 184 02 25 list $7.76 Aug 2011 cartridge oil filter for diesel with o-ring for filter cap000 4591 V001 0000 00 list $18.80 Jan 2011 air filter cartridge001 993 79 96 list $20.37 June 2011 V-belt000 993 34 96 list $14.39 June 2011 belt-AC000 5691 V003 C69A00 list $6.81 Tomato red, clock trim ring000 5691 V003 CC7A00 list $6.81 Silver, clock trim ring001 2539 V004 C96A00 coupe wiper switch with cruise control001 2540 V004 C96A00 cabrio wiper switch with cruise control000 1562 V010 C96A00 cabrio wiper switch without cruise000 4673 V002 C41A00 list $151.40 Nov 2010 passenger side roll down window glass000 5591 V002 C22A00 list $86.27 Jun 2010 front lower spoiler (the unpainted part)000 9226 V001 C22A00 list $19.66 Jun 2010 air spoiler for rear wheel l,r?000 9227 V001 C22A00 list $19.66 Jun 2010 air spoiler for rear wheel l,r?000 9463 V001 000000 list $16.01 May 2010 cabrio waterproofing spray
Edited by gordo.bernard
EGR signal attenuator harness: Q0019185V001000000
A008 989 55 71 Fluid-Set 2 ml electrical contact enhancer. $30... HOLY CARP! It's made in the US for AMG, but it sells for EUR 7.00 in Europe (about $11).
It's a thin, clear liquid with a carrier that evaporates; no zinc or grease or silicones. I put it on the N9/3 connector at the EDG as well as on the contacts in the clutch actuator and gear position sensor plugs.
Screws to attach the rear upper covers for brake light and washer motor:
The EPC illustrates both parts as the same, but there are mostly short screws and then two longs screws. The cost the same @ $2.00 each.
Short: 0004132V001000000
Long : 0004135V00100000
B :sun:
Is there a better way to do this ?I would find this list very helpful if it could be easily updated and maintained.Very few people have a full Adobe software package tho, so updates can't get done easily.I thought, what if the document was a pdf and an xls. People could easily update the xls, and Excel can create a pdf that can then be posted.Nice idea ... and I went and did it.parts.pdfWorked rather easily, but the catch was, we cannot upload xls files.So much work to do correctly, or $ for software. Shame we cannot make this easier.Thoughts ?
I use a mac, so I did the spreadsheet and exported as a PDF. The only other way - to keep it simple - is to upload that spreadsheet to Google Docs, let everyone have access and then link to it in this forum. Wiki might be a good idea to.
Riveted chain link (timing chain): Q0007681V0010Originally mentioned by Tolsen in the "Cylinder Head, Need infos to replace a cylinder head" discussion started by dieselkiki.
Cam chain = 660-997-00-94Cam sprocket, upper = 660-052-01-01Cam sprocket, lower = TBDOil pump chain = TBDOil pump sprocket = A660-181-00-12Info from "Cylinder Head, Need infos to replace a cylinder head" discussion.
0022175 V002 000000 - BRABUS cdi dual exhaust vibration damper block (attaches to the threaded rod on the top left of the exhaust)0011927 V002 000000 - BRABUS cdi dual exhaust clamp/bracket (attaches to the transmission housing)
0008100 V002 000000 - right hand side plastic frame nut/well nut for lower head lamp mount.
Stretch Bolt Part number: 0001906V005000000Long bolt that attaches the front wheel assembly to the strut, cost was $16.60 for two including taxes
