Krasteff
Harsh Engine stop when turning off car
7 posts in this topic
Hello all,
This is probably an obscure problem but what could cause a "too harsh" stop of the Engine while turning car off?
The Engine seems to be in very good condition with great mileage, great startup, feels balanced and smooth enough but is like when you shut the Engine it vibrates too much and the stop is a little too immediate like if there is too much friction if you know what I mean but I guess the real reason is not friction but excessive Engine vibration while shutting off, the Engine mounts should be good as I don't feel anything while changing gears, the only two non stock things I have is egr Block plate and ccv to atmosphere
Edited by Krasteff
Engine mounts I would guess....if they have never been changed, that will definitely be part of it.
Yes is probably the most likely thing, even if I don't feel anything strange while changing Gear Engine mounts could still be bad, right? Also the central one or only the side ones?
Edited by Krasteff
Engine mounts aren't that costly but the front centre one can be a nasty one to replace.  Also do not buy the performance version unless you like a harsh driving experience.....stock ones are far better.
Thank you, just for knowledge, what are other classic symptoms of bad engine mounts?
Vibrations....and the sounds that come from them,
