@  Th3Guardian : (23 July 2016 - 03:55 PM) Wondering if anyone has a performance exhaust for a 451 in Ontario
@  BabyBenz : (23 July 2016 - 03:03 PM) Shuanghuan Noble
@  BabyBenz : (23 July 2016 - 03:02 PM) Came across an interesting article about a Chinese auto manufacturer that cloned the Smart Fortwo - was sued for copyright infringement but the suit failed.
@  smartzuuk : (21 July 2016 - 11:20 AM) no bites yet on the canada1.... it's still at 98,xxx kms with brand new tires and if someone is interested, let me know.... because if the Volvo goes first, the smart will come off the chopping block
@  Nigel : (19 July 2016 - 03:45 PM) Talk to Glenn smart142. I know he has been in contact with another welder about repairing stock mufflers.
@  Mike T : (19 July 2016 - 01:21 PM) Does Eddy in BC have a decent used one?
@  BabyBenz : (19 July 2016 - 12:44 PM) Trying to decide whether to pull the trigger on expensive muffler replacement at Mercedes or try and have an exhaust shop make a hopefully cheaper custom replacement.
@  Henry : (14 July 2016 - 03:13 PM) Carrot river is in north east Saskatchewan.
@  Henry : (14 July 2016 - 03:12 PM) Ya the cruise helps a lot. i have taken my smart as far east as Carrot river and as far south as palm springs. Quite comfy for the driver but the passenger doesn't get a reclining seat.
@  Mike T : (14 July 2016 - 06:29 AM) Yup. Top tip: Get cruise control, if you don't already have it.
@  Surturiel : (14 July 2016 - 06:09 AM) hmmm... So, just the usual (change oil, check everything), cram the car full of junk and head for 8 days of road?
@  smartzuuk : (14 July 2016 - 04:47 AM) It won't change things enough to matter... I've driven all the way from BC to Labrador and return on the stock wheels and tires....
@  Surturiel : (13 July 2016 - 11:48 PM) Should I put on wider wheels for the trip? would that make it more bearable? (roadster steelies+conti procontacts)
@  Mike T : (13 July 2016 - 06:18 PM) No problem. I did Toronto to Vancouver Island in 4 days!
@  Surturiel : (13 July 2016 - 05:01 PM) question: I *might* move from Vancouver to Halifax, and was thinking about driving all the way there with my 450. Stupid or REALLY stupid idea?
@  Surturiel : (13 July 2016 - 05:00 PM) hey, everyone
@  Mike T : (11 July 2016 - 08:10 PM) me too
@  dmoonen : (11 July 2016 - 04:59 PM) So I've totally missed updating my bike totals haha
450 CDI oil leak diagnosis
  • Please log in to reply
59 replies to this topic
#1 kayble
kayble
  • Regular Members
  • 72 posts
Posted 12 April 2009 - 09:12 AM
Hi all,
I'm a UK 2001 Fortwo CDI owner and am trying to trace an oil leak that's appearing around my intercooler and then appears to be dripping down on to the left hand side (looking from the rear of the car) transmission casing from the left/bottom intercooler body corner.
To try to find the leak, I have renewed all the jubilee clips on my turbo / intercooler hoses and made sure they are tight and used carb cleaner to make sure the area is clean for me to find the leak. I also eliminated the engine breather hose by unhooking it from the TIK and blocking the hole.
I *think* I have found the cause of the leak but would like to confirm with other owners if they have also found this leak previously. I think the leak is coming from the air temperature sensor that is inserted in to the bottom of the intercooler body that sits just above the transmission casing / driveshafts. I have a picture of the offending part:
That picture is actually much cleaner than the offending part of the car usually is. Typically, the sensor is caked in oil and traces of it can be seen coming down on to the transmission casing. There is a small 'O' gasket on the sensor as it is inserted in to the intercooler and I think this may have failed, allowing what oil there is in the intercooler from the engine breather to blow past the sensor and out of the intercooler.
Has anyone else seen this? I hope I'm not barking up the wrong tree - and really hoping it's not a fractured intercooler!
Thanks,
John
Edited by kayble, 12 April 2009 - 12:48 PM.
#2 Mike T
Mike T
  • Directors
  • 29,129 posts
  • Gender:Male
Posted 12 April 2009 - 09:24 AM
That could well be - my car has the same leak (which comes and goes). Please let us know if you find a replacement O-ring that suits, as I wouldn't mind trying that out as well.Your photo is excellent and that does appear to be a low point in the system so maybe it can be used as a natural oil drain cock for the intercooler! A regular bleeding might take care of things!As far as the intercooler being fractured, even with the leak, my Scan Gauge reports manifold absolute pressures of 2.17 bar under full load (which is to say, turbo boost in the manifold of 1.17 bar, compared to 1.15 original spec), so it is not leaking any compression produced by the turbocharger. The way I look at it, if you can live with the mess from the oil leak (it shouldn't be all that bad, as the source is only re aspirated oil fumes as you know) and the intake system holds turbo compression, the intercooler ought not to need to be replaced.One thing you can to do try and minimise the leak is to maintain the oil level in the sump around 1/2 way up the dipstick - no higher - but maybe you know this already. Or is your detachment of the oil fume hole permanent? I would hesitate from blocking that hose off, as crankcase pressure could built up from compression bypassing the piston rings, which would eventually blow oil out of the engine's seals. Better then to let the oil fumes escape to the atmosphere....
#3 kayble
kayble
  • Regular Members
  • 72 posts
Posted 12 April 2009 - 10:02 AM
hey mike,thanks for the quick reply. Yes, I'm aware that the oil level should be on the lower side to keep residual oil vapour loss to a minimum - learned that from this forum aaages ago!When i said I had blocked a hole, I meant the TIK hose hole where the engine breather hose should be. The breather is presently free to vent to atmosphere while I diagnoses the leak, but the TIK is plumbed up.As we sppeak, I'm working up a process (with pictures) for removing the CDI intercooler - with a view to checking for perforation damage to the intercooler itself that might actually cause the leak, which is fooling me to think it's the gasket on that air temp sensor.I'll check back soon :)
#4 Mike T
Mike T
  • Directors
  • 29,129 posts
  • Gender:Male
Posted 12 April 2009 - 10:40 AM
Aha, you have it all under control then. Keep up the good work!
#5 bilgladstone
bilgladstone
  • Regular Members
  • 12,116 posts
  • Gender:Male
Posted 12 April 2009 - 11:43 AM
Hi Kayble, I think we just followed the same trouble-shoot with Ed. His discussion is here: http://clubsmartcar....s...st&p=223071 We'll all benefit from - and appreciate! - your documentation of the intercooler removal process. Cheers, mate Bil :sun:
#6 kayble
kayble
  • Regular Members
  • 72 posts
Posted 12 April 2009 - 12:42 PM
Thanks Bill,I had a read through - the post makes it clear that there's a wear/tear issue with the intercooler and it's plastic housing. I'll get a clearer look tomorrow but I guess I'm looking for some evident holes/ damage caused by interference between the intercooler and some plastic shrowd somewhere. I just took the car for a run and oil has once again appeared towards the lower corner of the intercooler - but above the air temp sensor which is still dry so I think that's a red herring.We shall see tomorrow (weather pending)! :)
#7 kayble
kayble
  • Regular Members
  • 72 posts
Posted 13 April 2009 - 10:51 AM
Ok guys,
I had good weather so I took the intercooler our for inspection today:
Step 1 Remove the back panel - detailed here. You will be left with:
Step 2 Remove the rear crash bar. There are six T45 bolts holding the rear crash bar and rear valance mount holes. You will be left with:
Step 3 Remove the TIK hose. There's a jubilee clip at the airbox and another at the turbo. Don't forget to recover the seal that goes round the turbo inlet. with the TIK removed, you'll see this:
Step 4 Remove the exhaust. This helps a mile with accessing the intercooler hoses. Sorry didn't remember to take a picture of the car with the exhaust off.
Step 5 Working from the top of the engine, remove the upper EGR valve intake hose:
Step 6 Unplug the electric intercooler fan. Next, unclip the the wiring loom section that attaches to the fan. Next, using a pair of pliers or something suitable, pinch together the two tabs in the top middle of the cooling fan assy to pull the top of the fan assy away from the intercooler. Rock the entire fan assy forward and away from the top of the intercooler and the bottom fan clips will unclip - but be gentle with it. You will be left with:
Step 7 Unclip the intercooler air temperature sensor connector from the bottom of the intercooler housing. Next, unclip the sensor from the connector coming from the wiring loom and set the sensor aside somewhere safe - it's fragile. The sensor is located to the lower left of the intercooler when looking from the rear of the car and looks like:
Step 8 Remove the lower intercooler / EGR hose. First, unclip the circlip from the bottom of the EGR valve:
This picture wasn't taken in series, which explains why the cooling fan is still there! Next, undo the jubilee clip on the hose at the intercooler end. Finally, manipulate the hose out of the EGR valve then off the intercooler. The part looks like this:
Step 9 Remove the lower intercooler / turbo inlet hose. Undo the jubilee clips at both ends and manipulate those out. This one is a royal PITA to get out by the way! It looks like this:
Step 10 Phew - finally we get to remove the intercooler. It is secured by four plastic clips on the top and bottom of each side of the intercooler. You need get a thin flat bladed screw driver and carefully press it in to the centre of each clip to disengage it from the plastic housing. You'll see what I mean when you get there. Disengage each clip from the sides of the intercooler and *gently* pull it forward. As with the cooling fan, pull the top of the intercooler forward and away from the rear housing first. You can then manipulate the intercooler up and out of the engine bay. Be careful not to damage the semi rigid diesel fuel return line or any of the wiring loom parts as you remove the intercooler. With intercooler out, you will see the air scoop housing as shown below - with the plastic clips that engage with the intercooler also shown:
That's it for the moment as I have to dash out. I've got more pictures and information concerning the nature of the oil leak from the intercooler and the vibration damage / play issues relating to the air scoop housing against the intercooler and also what I've done to hopefully stop both the leak on the current intercooler (hopefully) and prevent the air scoop assy from fouling this and any other intercooler I put in the car!
Edited by kayble, 13 April 2009 - 10:55 AM.
#8 ianjay
ianjay
  • Regular Members
  • 1,222 posts
  • Gender:Male
Posted 13 April 2009 - 12:45 PM
Hope it all fits back together. Great pictures. Looking forward to more.Ian
my ex - '05 Pulse stream green/black tridion cabrio, a/c (?), fanfare, CD changer, Loblaws beach towels (smiley serpents or smiley faces) on seats, "GOTSMART" plates, ordered Sept '04, delivered Feb '05, was under the care of Uncle Glenn and Liz and now CANMAN!
INSPIRED BY my smart, I'm going to lounge around in a white Fiat 500 for a while. It is just crazy enough.
And now, our Volt is here!
#9 mzeeb
mzeeb
  • Regular Members
  • 142 posts
  • Gender:Male
Posted 13 April 2009 - 02:27 PM
Fantastic series of pictures; having something like this on hand really helps to "picture" the text of this, and other, DIY threads.Can't wait to see the outcome of your intercooler inspection and the remaining pictures!MZ
2005 Passion cabrio: phat red/black tridion, heated black leather seats, locking drawer, pollen filter, cupholder, paddle shift
Mods: euro turn signals, oil pan heater, K&N filter, scan gauge, ignition free windows, remote window switch, tach & clock pods, clear/amber side LED's, flashing side markers, vortex generators, headrest speakers, 4 channel Pioneer head unit, arch extensions front and back, Prosport boost gauge in clock pod, H&R sport springs, wiper arm spray mod, tint, factory cruise control, remap and upgraded intercooler fan.
#10 kayble
kayble
  • Regular Members
  • 72 posts
Posted 13 April 2009 - 03:52 PM
Ok guys,
More information as promised. The last post showed the method for getting the intercooler out - but what of the intercooler now that it has been removed? We'll the purpose of the exercise was to diagnose an oil leak apparently coming from the intercooler body and dripping down to the tranmission casing and driveshafts.
Other posts have detailed that the intercoolers in our cars are prone to vibration/play damage issues against the air scoop housing that the intercooler sits in. With this in mind I looked at my car intercooler a bit closer. Here's what I found, after a bit of carb cleaner was sprayed over it to clear off the oil vapour muck:
Intercooler front end (facing you as you look at it from the engine bay):
All looks ok on this side of the intercooler - but flip it over:
This is the lower left corner of the intercooler. You can see some light indentations towards the bottom of the metal assembly where the intercooler has been rubbing against the lower lip of of the intercooler/air scoop housing. There are also some more indentations slightly up the intercooler by the plastic clip that holds the intercooler on the housing.
These indentations had not yet perforated the intercooler fins - so where is the leak coming from? Ah ha! Here's a closer look of the edge of the intercooler from where the leak was emanating:
If you look at the intercooler, you can see that it has a top and bottom plastic piece with a metal finned assembly in the middle. The top and bottom pieces are 'crimped' tight in to the metal piece however you can see that in the above shot, the crimps are giving way and, I believe are allowing oil to seep out. Here's another close up pic:
The dips in the metal part of the intercooler should be tight against the relevant dips in the plastic piece to form a tight seal. This was the case for each crimp on the short edge of the intercooler at the leaking end and also half way down the long edge that was rubbing against the air scoop housing. To try and resolve this without having to buy a new intercooler I knocked the bottom lip of the intercooler on to the plastic piece and then took a large pair of pliers and pressed the metal dips back on to the plastic piece. Afterwards, the above pictured part of the intercooler looked like this:
You can see that metal crimps are now tightly down on the plastic lower piece of the intercooler. Also, on the longer edge of the intercooler:
Now - what did I do to ensure that the rubbing/ play issues wouldn't be a problem? I 'modified' the air scoop lip - by removing it! Take a look:
Basically, I removed the entire bottom lip of the air scoop housing to stop it from rubbing against the intercooler. I did this very simply with a pair of pliers and snapped the plastic the length of the scoop then cleaned it up with a stanley knife. I also removed the two indentations by the plastic clip that holds the intercooler in place on the air scoop.
And that's about it - I reassembled the car which is the reverse of taking it apart. I shall monitor the situation in the next few weeks and see if the leak is stopped or greatly reduced. If not, I'm probably looking at a new intercooler, or some more work to try and seal it up. For reference, the part number I took of the intercooler is: 000 2400 V005 as shown in:
I'll report back in a few days :)
#11 Mike T
Mike T
  • Directors
  • 29,129 posts
  • Gender:Male
Posted 13 April 2009 - 04:00 PM
Brilliant stuff, kayble!Would a dose of silicone sealant once the intercooler is apart and clean have made up for any defects in the crimp seal? It would seem that actual perforation of the intercooler is not the usual failure mode, but rather a loose crimp, which would probably be impossible to prevent with a new intercooler, given enough time.I am wondering if we should see if an aftermarket intercooler firm could make up an all aluminium one for us for - perhaps - no more than the disposable piece that is OE.
#12 bilgladstone
bilgladstone
  • Regular Members
  • 12,116 posts
  • Gender:Male
Posted 13 April 2009 - 04:26 PM
Well done, Kayble! :bowdown:
I am not much concerned with oil leaking out, so much as very bothered that the intercooler is not a sealed unit. If it leaks like this under boost, we are losing boost pressure out the holes. And with no boost, I suspect that unfiltered, very dirty air can be sucked into the manifold!
How many km on your engine, Kayble?
And do you think it would be possible to squeeze a silicone bead around the offending gaps from beneath the car, with the intercooler in situ?
Much impressed.
Bil :sun:
#13 Mike T
Mike T
  • Directors
  • 29,129 posts
  • Gender:Male
Posted 13 April 2009 - 04:35 PM
Here's the thing - mine leaks and the boost is 100% normal in the manifold, in fact a little better than stock, as it always has been. Also, since this is a pressurised system, I doubt dirt would be leaking into it. That's the least of the concerns!I'm in no hurry to change my intercooler, based upon this excellent work! Thanks!
#14 Duck
Duck
    Crazy Quacker
  • Regular Members
  • 9,247 posts
  • Gender:Male
Posted 13 April 2009 - 05:31 PM
I think you guys have all missed the whole point though:There should be NO oil passing through the intercooler!Kayble; brilliant documentation, the problem you have is the exact problem that has plagued my car for it's entire 230 000+ km life. The left half of the transmission casing gets soaked in oil, dripping down from the air sensor... all caused by the oil which is leaking out of the turbocharger's compressor side hydrofluidic bearing seal... clogging the intercooler and EGR."Sealing" the leak will only hide the problem, not solve it. :(-Iain
126087.png 2006 smart fortwo cdi Nosedive....Dead again...
416440.png 2010 Toyota Gen3 Prius Normandy (N7)- Hybrid Synergy Drive active!
#15 Mike T
Mike T
  • Directors
  • 29,129 posts
  • Gender:Male
Posted 13 April 2009 - 05:58 PM
In my case I would be inclined to think that even if some oil is getting past the turbo bearing seal, it's typically a minute amount and the only reason for concern is if the intercooler were to become totally clogged with oil (which, as we see, is unlikely, as it tends to leak out before it can fill). My car "uses about 0.2 L of oil over 10,000 km service intervals and probably more than half of that is combusted in the cylinders.So the real question is: in a typical cdi, what is the proportion of oil in the intercooler attributable to a leaking turbo seal, and what is the proportion attributable to the CCV system? Hard to say. If your car - like mine - is FAR under 0.05 L/1000 km of oil loss and never needs an oil top-up, my bet would be it's CCV that is contributing most of the oil to the intercooler.By the time the oil is in the intercooler, it's not going to affect the turbo at all so it is probably an aesthetic issue only (drips, messy transaxle casing), in cases where the oil loss from the engine is so minimal as to not require oil top-ups.I'm going to sit on my leak for a while yet. No point changing it, as the new intercooler will do the same thing, and so on, and so on.......
#16 kayble
kayble
  • Regular Members
  • 72 posts
Posted 14 April 2009 - 12:37 AM
So the real question is: in a typical cdi, what is the proportion of oil in the intercooler attributable to a leaking turbo seal, and what is the proportion attributable to the CCV system? Hard to say. If your car - like mine - is FAR under 0.05 L/1000 km of oil loss and never needs an oil top-up, my bet would be it's CCV that is contributing most of the oil to the intercooler. By the time the oil is in the intercooler, it's not going to affect the turbo at all so it is probably an aesthetic issue only (drips, messy transaxle casing), in cases where the oil loss from the engine is so minimal as to not require oil top-ups.
I agree - it's not the case that there should be absolutely NO oil in the intercooler. I think that in regularly maintained engines, the CCV system is wayyy more responsible for putting oil in to the intercooler than any wear on the turbo bearing. That is, after all, the CCV system's 'raison d'etre'. Also, the quantity of oil you typically find WITHIN the intercooler is minute and is IMHO the product of having allowed the engine to cool and the vapourised oil to condense at the bottom of the intercooler since we tend to take our cars apart when the engine is cold. Of course, what you find splattered over the transmission casing, or round your CCV breather hose as it connects to the TIK, or round the turbo inlet / outlet makes the problem look much worse than it is. but don't forget - it only takes a very small amount of oil to make an engine look like it has a bigger problem. To answer q's about silicon sealant. I think that would have been a good idea - but perhaps if you intended to take the plastic bottom of the intercooler off entirely. I think the longer term solution would definitely be to replace the intercooler with a one piece aluminium item. As for adding silicone with the intercooler in situ - I don't think you'd have the necessary access - removing it would be the best idea. By the way, if anyone fancies doing a group purchase for an intercooler, just let me know - I'm good for one :)
Edited by kayble, 14 April 2009 - 12:48 AM.
#17 kayble
kayble
  • Regular Members
  • 72 posts
Posted 14 April 2009 - 03:09 AM
More information for you:The latest number for the diesel intercooler, as provided by a friendly Mercedes Smart dealer is: Q0002409V007000000.Don't quote me on this but it would seem the that the 'V007' bit of the number implies that the part has changed since my 'V005' part. It would be interesting to compare the two...
#18 smart142
smart142
    moderator
  • Global Moderators*
  • 7,526 posts
  • Gender:Male
Posted 14 April 2009 - 04:12 AM
Thanks for the great pictures and info :thumbsup_anim: That explains the damage on this intercooler......
Glenn.
2005 Passion coupe Bay grey-silver-loaded! ''Gina'' (deposit 1Nov02,delivered13Dec04)SOLD! 12 Sept 2014 - 3 months shy of 10 year ownership. Now driving a 2005 loaded passion. 2016 ED leased for 3 years
4.4
#19 kayble
kayble
  • Regular Members
  • 72 posts
Posted 14 April 2009 - 04:41 AM
yeeeeouuuch!That's obviously perforation damage caused by the lip on the intercooler air scoop housing. Mine hadn't gotten so far - which was lucky!
#20 mzeeb
mzeeb
  • Regular Members
  • 142 posts
  • Gender:Male
Posted 14 April 2009 - 05:10 AM
Great post and excellent pictures.I can't help but wonder whether these "loose crimps" aren't a design flaw or quality control issue......I would have been tempted to take the failing intercooler to the local MB dealer for an opinion; it really shouldn't loosen up like that on its own - after all it was engineered to go into a diesel!
#21 kayble
kayble
  • Regular Members
  • 72 posts
Posted 15 April 2009 - 11:48 AM
ok guys,The leak is virtually eliminated. There's a slight wisp of oil on the intercooler casing but its 95% less than previously. I think if I had used silicone sealant it would have done the trick. Next time I get chance, I'll take the intercooler out and try it again. That said, if I can get a nice aluminium intercooler, that would be wayyyyyyyyyyyyy better!
#22 Mike T
Mike T
  • Directors
  • 29,129 posts
  • Gender:Male
Posted 15 April 2009 - 11:56 AM
Super, thanks for the tips!We ought to get someone with a spare intercooler to get a group buy price from a manufacturer of proper intercoolers....
#23 kayble
kayble
  • Regular Members
  • 72 posts
Posted 17 April 2009 - 03:07 AM
Super, thanks for the tips! We ought to get someone with a spare intercooler to get a group buy price from a manufacturer of proper intercoolers....
Oh yeah - I'd be very much up for that. Not sure who to approach etc. Don't suppose anyone has a technical diagram for the intercooler with measurements etc? I can find a bunch of intercooler places on web that are based in the UK. In the absence of having a spare intercooler, I could always send over a diagram etc.
#24 bilgladstone
bilgladstone
  • Regular Members
  • 12,116 posts
  • Gender:Male
Posted 17 April 2009 - 07:30 AM
Or maybe even have them make a metal version of the lower plenum and weld it to the core...?
#25 Mike T
Mike T
  • Directors
  • 29,129 posts
  • Gender:Male
Posted 17 April 2009 - 12:03 PM
I bet that core is wafer-thin and unweldable.
#26 bilgladstone
bilgladstone
  • Regular Members
  • 12,116 posts
  • Gender:Male
Posted 17 April 2009 - 12:22 PM
pop-rivet the plastic to the metal lip?
#27 bilgladstone
bilgladstone
  • Regular Members
  • 12,116 posts
  • Gender:Male
Posted 17 April 2009 - 03:40 PM
OK! In discussion over on smartmaniacs [read details on this link], we've determined that the modification that kayble describes (see snippet from his great how-to below) can be done by removing the intercooler scoop from under the car with the intercooler left in place. There just HAD to be a simpler remediation than removing the whole kit... and there IS!
Jeez, I wish I had (or could afford) some kind of car lift! :banghead:
... Now - what did I do to ensure that the rubbing/ play issues wouldn't be a problem? I 'modified' the air scoop lip - by removing it! Take a look:
Basically, I removed the entire bottom lip of the air scoop housing to stop it from rubbing against the intercooler. I did this very simply with a pair of pliers and snapped the plastic the length of the scoop then cleaned it up with a stanley knife. I also removed the two indentations by the plastic clip that holds the intercooler in place on the air scoop ...
#28 kayble
kayble
  • Regular Members
  • 72 posts
Posted 21 April 2009 - 05:28 AM
ok guys,I've contacted an intercooler fabrication company and asked them for a quote to replace my intercooler with a one piece aluminium part. I'll let you know how I get on.
#29 smart142
smart142
    moderator
  • 7,526 posts
  • Gender:Male
Posted 21 April 2009 - 07:05 AM
Excellent!Thanks for the update. I would be interested in one as I am now over 140,000 kms
Glenn.
4.4
#30 Mike T
Mike T
  • Directors
  • 29,129 posts
  • Gender:Male
Posted 21 April 2009 - 10:05 AM
Same here. And thanks.
#31 ianjay
ianjay
  • Regular Members
  • 1,222 posts
  • Gender:Male
Posted 21 April 2009 - 11:18 AM
I'm also interested, although shipping from the UK might not make sense.
#32 Speedie
Speedie
    Former Chief cook and bottle washer
  • Administrators
  • 6,829 posts
Posted 21 April 2009 - 08:48 PM
Couple companies in the states make them for racing as well - also the hot swap in Australia is to find a Japanese car with a water to air cooler and use it for a non-intercooled or an air-air intercooler - some of the smaller engines turbo engines might be prime candidates - nice and compact - don't need a fan and cheap too! Cheers,Cameron
"Lucy" 2006 Passion - Ruby Red - sunroof - black tridion
"NuBlu" - 2006 Pulse - Star Blue - black tridion - in need of some TLC
1994 Jeep YJ
1990 Dodge D250
#33 kayble
kayble
  • Regular Members
  • 72 posts
Posted 10 May 2009 - 12:13 PM
Evening all,
Well I gave up on the one piece aluminum intercooler idea in favour of attempting to repair the original part.
The original method of simply pressing the crimps of the metal core back on to the lower plastic piece of the intercooler didn't work for long. So I took the intercooler off again and had a go with a suggestion from this forum of having a go with some silicone sealant as you might get from a DIY shop.
With the intercooler off, I carefully released all the crimps on the bottom of the core to release the lower plastic plastic part that attaches to the air hoses from the turbo and EGR valve:
When you remove the lower piece of the intercooler, you'll see there is a thin black rubber gasket between the plastic and aluminium parts. This gasket had gone thin and brittle in the area that the intercooler was blowing from:
With the bottom of the intercooler off, you can get a look at the core:
Having cleaned up the mating area around the gasket (note the cack to the left of the core in the picture from where oil vapour had been blowing), it was time to put it back together. The next step is to lay a line of silicone sealant on the intercooler core and lay the gasket in it. Then I put another line of sealant over the gasket and sat the plastic part back on to the core. It was a bit of a messy job to say the least - yes that is the kitchen sink in the pictures lol!
Push all the crimps back in and then replace the part on the car. Leave it to cure over night as well or the silicone sealant won't be strong enough before you put pressure through the intercooler.
Having done all that, and then cleaned the sump off with carb cleaner, it has remained bone dry since - about 3-4 weeks now.
Unfortunately, this isn't much use if the core has been knackered by the intercooler scoop.
Edited by kayble, 10 May 2009 - 12:14 PM.
#34 Mike T
Mike T
  • Directors
  • 29,129 posts
  • Gender:Male
Posted 10 May 2009 - 03:16 PM
Good plan! I wonder if a scoop-damaged intercooler could be soldered shut again, with thin patches.Did I mention I'm cheap (or more likely, that I think this part is not worth $500).
Edited by Mike T, 12 May 2009 - 05:56 AM.
#35 Speedie
Speedie
  • Administrators
  • 6,829 posts
Posted 11 May 2009 - 09:40 PM
Better off with some JB weld or other adhesive type product (urethane would be my choice) - trying to solder or weld the intercooler would be a challenge (thin metal - and for some reason really good at conducting heat away....)Cheers,Cameron
1994 Jeep YJ
1990 Dodge D250
#36 Bigrick
Bigrick
  • Regular Members
  • 129 posts
Posted 04 June 2009 - 09:16 AM
Seriously happy to find this post. My 85K Smart (only two years old but now out of warranty) started dripping about two months ago, just before the warranty expired. MB Halifax took a look at it and basically told me that a) the hoses, etc. were fine so nothing to replace and B) "they all do that" once they get old enough for the blowby oil to have accumulated to a certain level in the intercooler. Nice to know it's nothing fatal but does make a mess of my garage floor or washed aggregate driveway. It started not long after the last B service, so wondering if they may have topped the oil up a little too much at that point...I don't much believe in coincidence.I'll keep an eye out for updates on the silicone repair and if it gets any worse, or I simply get sick of scrubbing the concrete, I may have to try this one myself.Rick
#37 bilgladstone
bilgladstone
  • Regular Members
  • 12,116 posts
  • Gender:Male
Posted 04 June 2009 - 10:52 AM
I absolutely hate it when they say, "They all do that!" What a stupid and lazy answer. Translation: "Your warranty is over, now bug.ger off."Bil :sun:
#38 Mike T
Mike T
  • Directors
  • 29,129 posts
  • Gender:Male
Posted 04 June 2009 - 03:44 PM
They probably do all do that.....but it is annoying. Nothing grave though.
#39 deezle
deezle
  • Regular Members
  • 3,047 posts
Posted 04 June 2009 - 04:15 PM
There's gotta be an easy way to just screw in a little drain valve to drain the condensed oil vapor?
#40 bilgladstone
bilgladstone
  • Regular Members
  • 12,116 posts
  • Gender:Male
Posted 05 June 2009 - 10:53 AM
... or divert the stupid CCV return line to a catch tank before it even gets to the intercooler in the first place! :sun:
#41 Bigrick
Bigrick
  • Regular Members
  • 129 posts
Posted 05 June 2009 - 12:59 PM
I absolutely hate it when they say, "They all do that!" What a stupid and lazy answer. Translation: "Your warranty is over, now bug.ger off." Bil :sun:
I concur. Week before last, we finally had a warm day. No cold air from the air conditioner. No question, it quit sometime during warranty period but I sure don't have any commitment for consideration (re-charged the system with dye added to try and find leak). Also found that the resistor in the fan switch was toast - it's been like that for so long, I didn't realize that I only had Hi on it. No commitment on consideration for that. And my favourite - hi beam was burned out, so asked them to change it while they were looking at the air...found that the headlight unit was broken, probably my own fault trying to change a bulb w/o removing the front end, but a $400 part tp replace. So, summary of yesterday's visit...I still leak on my concrete, air is still unknown, estimate is about $120 to fix fan when part arrives and my lights are now fixed, thanks to a total bill of $716 and change. I'm saving fuel all the way to the Poor House. Rick
#42 mlg
mlg
    mlg
  • Regular Members
  • 81 posts
Posted 10 June 2009 - 03:19 PM
I have been reading with interest on this intercooler issue - I just had my almost 4yr 54,000 is kms in for a service and they detected an oil leak which they eventually attributed to "valve leak on intercooler" and will have to order 2 seals from Germany.I run biodiesel and wonder if this accerbates any seals or if this is just faulty valves/seals.
2005 Pulse - Black Tridion/white panels - Twister blue interior - Storage Drawer - Clock/Rev Counter - Sound Package - Vanity Mirror - Brabus Pedals - Clear side markers - LED Dome & console light (cool blue) - cupholder
proudly Powered by BIOdiesel
#43 bilgladstone
bilgladstone
  • Regular Members
  • 12,116 posts
  • Gender:Male
Posted 10 June 2009 - 04:18 PM
Uh... I have to call :bs: on that one too. There are no valves on the intercooler. It is a simple air-to-air heat exchange matrix.
The two(?) seals may be the turbo seal as discussed above, and possibly an o-ring seal at the Intake Air Temperature sensor. Both of which are in Canada in abundance.
Perhaps they meant the power steering pump needs attention B)
Biodiesel has no effect on the seals or tubing.
Cheers,
Bil :sun:
Remember: I am just some guy on the Internet!
#44 Duck
Duck
    Crazy Quacker
  • Regular Members
  • 9,247 posts
  • Gender:Male
Posted 12 June 2009 - 08:16 AM
Keep in mind guys that the text that is written on your service report is just quickly keyed in by the tech working on your car, who has a million other things going on, grease on his hands, and wants to get back to working on the car. "Valve" might have been the first word that popped into his head, meaning the seal, or something else. It doesn't really matter, it's not like the dealership is trying to pull a fast one. It's just that whoever keyed in the report wasn't quite as literate as others! It would be nearly impossible to train every tech to use the exact same nomenclature on every single part of every car a dealership services.-Iain
#45 smart142
smart142
    moderator
  • 7,526 posts
  • Gender:Male
Posted 12 June 2009 - 08:39 AM
So what was wrong with Nosedive?
Glenn.
4.4
#46 Duck
Duck
    Crazy Quacker
  • Regular Members
  • 9,247 posts
  • Gender:Male
Posted 12 June 2009 - 01:20 PM
Verbally, turbo inlet seal - I'm still waiting for the car back because of delays getting new tires since no one knows how to get the strikeline tires!-Iain
#47 Mike T
Mike T
  • Directors
  • 29,129 posts
  • Gender:Male
Posted 12 June 2009 - 03:35 PM
I believe FastEddy has some in stock.
#48 Duck
Duck
    Crazy Quacker
  • Regular Members
  • 9,247 posts
  • Gender:Male
Posted 12 June 2009 - 04:03 PM
OK...I don't live in BC. :)I was lead to believe these were available as they were 451 tires - but apparently not, since they only became available on the market a few weeks ago from what I understand. So, the NA distributors are having a hard time tracking down stock. I still don't get how I'm having such a hard time finding tires, but other people have these same rims and have no problems!AAaaaaaaanyway, I dunno if this oil thing will ever go away. Sounds like it's just "how it is", so from now on I guess I just keep adding oil if the level looks to be too low, and live life and not worry.-Iain
Edited by Duck, 12 June 2009 - 04:05 PM.
#49 Mike T
Mike T
  • Directors
  • 29,129 posts
  • Gender:Male
Posted 12 June 2009 - 06:26 PM
Eddy could throw them on a Greyhound which would probably cost like $60....
#50 Duck
Duck
    Crazy Quacker
  • Regular Members
  • 9,247 posts
  • Gender:Male
Posted 15 June 2009 - 08:24 AM
I was lead to believe (by you, IIRC!) that they were now available in all dealerships because the 451 takes the same tires or something.-Iain
