@  steveyfrac : (23 May 2016 - 07:34 PM) Has anyone test drive the new 2016 Smarts yet? With a stick?
Might consider a Passion / Prime with a stick and Sport package if it drives nice.
@  dmoonen : (18 May 2016 - 07:09 AM) Honestly if youve driven one its so well put together, the NA VR6 engine just amazing.
@  booneylander : (18 May 2016 - 03:42 AM) That's a beauty! I always wanted to TDI-swap one. Diesel AWD!
@  dmoonen : (16 May 2016 - 06:40 AM) Just bought a MK4 R32. . . dam the music the exhaust makes in addictive
@  Mike T : (14 May 2016 - 08:22 AM) HO-dor
@  Francesco : (13 May 2016 - 09:55 AM) TUL-sa
@  Mike T : (13 May 2016 - 06:17 AM) Hee hee
@  DrZaius : (13 May 2016 - 04:14 AM) oops I thought this was the search box
@  DrZaius : (13 May 2016 - 04:13 AM) tesla
@  Francesco : (12 May 2016 - 05:56 PM) Yawn
@  Francesco : (12 May 2016 - 09:39 AM) Anybody (our industrial or mechanical types) have a contact at AdaptAll? Need two small fittings but don't know where I can get them...
@  Mike T : (09 May 2016 - 07:07 PM) The stubbies are probably crooked I tells ya! If you had a Peugeot 404, I have a stub axle alignment checker but since you don't, I wonder if Mercedes has one. Ask neighbour?
clutch actuator
  • Please log in to reply
22 replies to this topic
#1 smartmom
smartmom
  • Regular Members
  • 247 posts
Posted 27 October 2009 - 10:04 AM
My smart went "bang" and stalled last friday - when I tried to accelerate out of a stop light. After two more stalls I got it to limp along in 1 st gear to a safe spot.After a tow to my dealer I learned that the clutch actuator needed to be replaced.Factory warranty was up last month, and the extended warranty I bought does not cover this.(not original owner by a month and a half so not the smart warranty)Repair cost is $844 - it could be worse.
06 blue/grey Passion 450 Coupe red interior, clock, tach, drawer, funnel to add washer fluid (mine)
06 ruby red/ gray Passion 450 Coupe gray interior, clock, tach, drawer, heated seats (not mine)
#2 frankie5string
frankie5string
  • Regular Members
  • 89 posts
Posted 27 October 2009 - 10:08 AM
I'm kinda curious... has anyone ever considered rigging up some sort of manual override device? As in some sort of mechanical piston/solenoid setup to override the clutch actuator when it goes? Since the clutch appears to be dual-normal, it wouldn't seem all that hard to rig up something "Red-Green Style" to have manual control over the clutch...
Cheeri'o...
Frank...
#3 smartmom
smartmom
  • Regular Members
  • 247 posts
Posted 27 October 2009 - 10:13 AM
Hey, I had never heard of a clutch actuator before this morning.I turn on the key and magic happens. My scangage showed no codes, so I hoped the problem was not serious.
#4 Mike T
Mike T
  • Directors
  • 29,050 posts
  • Gender:Male
Posted 27 October 2009 - 11:25 AM
The actuator doesn't give ScanGauge codes. My actuator failed definitively at 88,000 km, cost all in was $750, It was allowing clutch slip on upshifts. Nearly 50,000 km on, it's fine.....I kept the old one, which might have only needed a bit of a lube.
#5 billr
billr
  • Regular Members
  • 108 posts
Posted 27 October 2009 - 11:53 AM
I lubed mine last week when I did the B service. Is there any adjustment check, or is that a MB function with the computer? Any need to have it done as preventative?
2005 Smart Passion Daily driver
Loaded "Piggyback" on Volvo when towing RV
#6 Mike T
Mike T
  • Directors
  • 29,050 posts
  • Gender:Male
Posted 27 October 2009 - 09:12 PM
Yes, there are three electronic clutch adjustments that should be performed every second service or so.
#7 billr
billr
  • Regular Members
  • 108 posts
Posted 27 October 2009 - 09:15 PM
Thanks Mike.
#8 Techman
Techman
  • New Members
  • 10 posts
  • Gender:Male
Posted 27 October 2009 - 09:24 PM
Hi, New to the club here!I had my clutch actuator fail in an intersection, at only 55,992Km <_< . Lucky, for me, I was able to limp it into the dealer, cost $85.01
#9 Techman
Techman
  • New Members
  • 10 posts
  • Gender:Male
Posted 27 October 2009 - 09:25 PM
opps for got a zero Cost was $850.01
#10 bilgladstone
bilgladstone
  • Regular Members
  • 12,116 posts
  • Gender:Male
Posted 27 October 2009 - 09:33 PM
Eddy did mine on the way to Vancouver Island. Second time adjusted in 80,000km. Lubed it myself once a year. This last adjustment was really a micro-tweak by request and it is absolutely plusquamperfectum!
B :sun:
#11 al goldfinch
al goldfinch
  • Regular Members
  • 111 posts
  • Gender:Male
Posted 28 October 2009 - 02:40 AM
Smartmom Is the extende warranty you bought from m/b dealer or from elseware because i thought the m/b one covered the same as the one that came with the car ?
#12 Francesco
Francesco
    CsC BoD Member
  • Directors
  • 6,214 posts
Posted 28 October 2009 - 04:34 AM
Hi, New to the club here! I had my clutch actuator fail in an intersection, at only 55,992Km <_< . Lucky, for me, I was able to limp it into the dealer, cost $85.01
They showed you the cost on a warranty work order? That's different. Edit: typo. Speedie, can we finally disable the edit time-stamp for new posts? Say, give a 10 minute grace period. I've ALWAYS hated it the way we have it set.
Edited by SameGuy, 28 October 2009 - 04:35 AM.
Francesco
2006 fortwo cdi pulse cabrio phat red/silver/heated leather/PLUS/sound mods Tempomat/Cabriotec glass rear window/custom red silicone cdi TIK/all-LED EU pulse lamps front & rear/mud-flaps/garage opener/wiper nozzle/SGII/remap/spin-on filter/K&N air/RS grille/de dion caps/Micro DE fogs/sucker/LED angel eyes/stainless EGR delete/RS paddles/HEL braided brake lines/Bilstein B14 PSS coil-overs/PowerFlex bushings/Michalak 16" wheels coming up Blindy/custom brakes/torque damper/Morimoto
#13 Speedie
Speedie
    Former Chief cook and bottle washer
  • Administrators
  • 6,829 posts
Posted 28 October 2009 - 03:15 PM
Have to find if there is a setting for that - also will need approval from the grand high poohpbahs.Cheers,Cameron
"Lucy" 2006 Passion - Ruby Red - sunroof - black tridion
"NuBlu" - 2006 Pulse - Star Blue - black tridion - in need of some TLC
1994 Jeep YJ
1990 Dodge D250
#14 Mike T
Mike T
  • Directors
  • 29,050 posts
  • Gender:Male
Posted 28 October 2009 - 03:42 PM
I've been asking for that for years, last word was it's doable but not wanted for some reason.
#15 Francesco
Francesco
    CsC BoD Member
  • Directors
  • 6,214 posts
Posted 28 October 2009 - 04:15 PM
The previous administration preferred it the way it is now. Mike and I have complained about it since Day One.
Francesco
#16 Speedie
Speedie
  • Administrators
  • 6,829 posts
Posted 28 October 2009 - 09:19 PM
You mean the previous-previous adminstration - matters not a hoot to me - get Glenn etc. blessing and I will make it happenMeanwhile - has anyone taken apart a failed actuator to see what gave up the ghost? The sector gear wear out or did the motor bag it from too much friction?Seem to recall a picture but I will have to do some digging so if some one has better grey matter and can remember off hand.Cheers,Cameron
1994 Jeep YJ
1990 Dodge D250
#17 Mike T
Mike T
  • Directors
  • 29,050 posts
  • Gender:Male
Posted 28 October 2009 - 09:40 PM
I still have mine but there are warnings all over it about NOT taking it apart (mega springs inside).
#18 smartmom
smartmom
  • Regular Members
  • 247 posts
Posted 28 October 2009 - 10:47 PM
"Is the extended warranty you bought from m/b dealer or from elseware because i thought the m/b one covered the same as the one that came with the car ?"I bought my extended warranty from the m/b dealer, but it was not the warranty offered to original owners.Mine is a "Secure Drive" Plus warranty by Sovereign Insurance - sold by my m/b dealer.My car had a previous owner and a couple of hundred kms when I got it. I was worried about the yearly A/C fixes I have needed and the unlikely but possible catastrophic engine blow up.the coverage looked pretty good, but a clutch actuator was not included -
#19 Francesco
Francesco
    CsC BoD Member
  • Directors
  • 6,214 posts
Posted 29 October 2009 - 05:31 AM
...But the clutch actuator should be covered under the standard 4 year/80,000 Km warranty. When was the car first registered?
Francesco
#20 Speedie
Speedie
  • Administrators
  • 6,829 posts
Posted 29 October 2009 - 09:08 AM
Put a bucket on your head and go for it Mike! :lol: :lol: :lol: :lol: Strange they wouldn't cover the accuator - even for wear and tear - that low of mileage for a major component failure is not considered normal.Cheers,Cameron
1994 Jeep YJ
1990 Dodge D250
#21 smartmom
smartmom
  • Regular Members
  • 247 posts
Posted 29 October 2009 - 09:44 AM
"But the clutch actuator should be covered under the standard 4 year/80,000 Km warranty. When was the car first registered? "My car was first registered about Sept. 22/ 05 - not by me. I was about 6 weeks past the factory warranty. Under 50,000 Kms.I tend to keep vehicles 10+ years, so more warranty is better peace of mind for me. (clutch actuators problems or not.)
#22 DJW
DJW
  • Regular Members
  • 233 posts
Posted 30 October 2009 - 10:55 AM
Question about the clutch actuator lubbing. What type of lube does it take? Is there a grease serk? If so what type of grease? I just put on 1,800 miles last week which took me to 21,350 miles. I am in VA and there is no place to get the B service done on our 03 European Gas smart so I will have to wait until I get back to the WA area to get it done.ThanksDennis
#23 bilgladstone
bilgladstone
  • Regular Members
  • 12,116 posts
  • Gender:Male
Posted 30 October 2009 - 12:31 PM
Question about the clutch actuator lubbing. What type of lube does it take? Is there a grease serk? If so what type of grease? I just put on 1,800 miles last week which took me to 21,350 miles. I am in VA and there is no place to get the B service done on our 03 European Gas smart so I will have to wait until I get back to the WA area to get it done. Thanks Dennis
Here ya go: http://clubsmartcar....showtopic=19141
