@  Mike T : (27 January 2016 - 01:03 PM) Get up stand up
@  SmartED : (27 January 2016 - 07:44 AM) "fall in"
@  Francesco : (26 January 2016 - 11:11 PM) "stand in"
@  Mike T : (26 January 2016 - 10:35 PM) "love in"
REAR brake indicator noise
  • Please log in to reply
20 replies to this topic
#1 Squeeakers
Squeeakers
  • Regular Members
  • 124 posts
  • Gender:Female
Posted 08 June 2011 - 04:01 AM
I'm wondering if anyone can tell me if the rear brake indicator noise is different from the front brake indicator noise?
I've heard the strange noise that the front brake indicator makes. The noise my little smart is making now is completely different from that. It's a very high pitched, metal rubbing sound. Like a very large broken cd player. I have to get my AC repaired soon anyway (33 degrees out today???) and I planned to get summer tires put on as soon as I can find something inexpensive enough to fit into my budget. So it's not a stretch to have them poke around at the brakes some, if that's the problem. I'm also considering that perhaps it's my front right shock, could it make that kind of noise if it was loose? I have had that wheel, mount, bearing, and rim replaced due to pothole last year. It's also been suggested that perhaps it's the interaction of my soft winter tires with the rim, or hubcap. I'm not finding that driving it is any different (other than the bizarre looks I'm getting from people as I squeal past them). It makes the noise less when I'm braking and turning than when I'm driving which was why I thought perhaps it was my rear brakes. Any thoughts?
Thanks,
Amber
'06 Fortwo Coupe Pure Jack Black
#2 Mike T
Mike T
  • Directors
  • 28,906 posts
  • Gender:Male
Posted 08 June 2011 - 06:21 AM
There is no rear brake "warning noise", so it could be the rear shoes are down to the rivets or metal (assuming they don't have brass rivets!) or the noise is being caused by something else. Our car's rear brakes squeal sometimes when it's wet outside.
#3 Squeeakers
Squeeakers
  • Regular Members
  • 124 posts
  • Gender:Female
Posted 08 June 2011 - 08:15 AM
Ah, I imagine that must be it then. I changed the front brake pads awhile back, but the rears haven't been changed yet. I'm fairly easy on brakes but they ought to be due by now. I bet that costs a fortune. :thumbsdown_still: Mine squeal all the time when they're wet too, this is definitely a different noise.
#4 CANMAN
CANMAN
  • Regular Members
  • 860 posts
  • Gender:Male
Posted 08 June 2011 - 08:21 AM
The longer you put off having the brakes fixed the more expensive it will be. (cause more damage)You should have done the rear brakes when you did the front ones.CANMAN
2005 steam green cabriolet, cruise control, armrest, side marker lights,
2006 phat red coupe, remote oil filter, armrest, remote battery booster, side marker lights, T.K's restrictor, scangauge, auto up/down windows,
#5 bilgladstone
bilgladstone
  • Regular Members
  • 12,116 posts
  • Gender:Male
Posted 08 June 2011 - 08:51 AM
I totally disagree. The front brakes do the lion's share of the work and the rears don't normally need replacing at anything like the frequency of the fronts.
Although... if a mechanic undertook to repair the front brakes and didn't bother looking at the back ones to see how much they were worn too, and if it turns out that they were so badly worn that they needed doing, then yes, they should have been done and the mechanic should be hit with a stick.
B :senile:
#6 MightyMouseTech
MightyMouseTech
  • Regular Members
  • 1,558 posts
  • Gender:Male
Posted 08 June 2011 - 09:00 AM
The longer you put off having the brakes fixed the more expensive it will be. (cause more damage) You should have done the rear brakes when you did the front ones. CANMAN
Um, unlikely. Rear drum brakes should last nearly the life of the vehicle if kept in proper adjustment.
Christopher "Mighty Mouse" C.
Life's too short to drink bad wine.
#7 Alex
Alex
  • Moderators
  • 2,388 posts
  • Gender:Male
Posted 08 June 2011 - 09:16 AM
True, but they should be serviced a few times, cleaned out and checked, adjusters lubed, parking brake cables lubed.A tiny pebble can get into the drums and make your sound as well as wear a groove into the drum. If a parking brake seizes the shoes will drag and wear. If an adjuster seizes the brakes won't adjust and will wear unevenly.
#8 Squeeakers
Squeeakers
  • Regular Members
  • 124 posts
  • Gender:Female
Posted 08 June 2011 - 11:04 AM
Ok, let's lay off the mechanic, it was me. :) I have no idea how to check my rear brakes, let alone change them. I only managed to do the fronts with some generous help. I'm not sure I could do it again on my own. I had my last official MB (before the warranty runs out) wrench check previous to the brakes, they advised changing the fronts, and possibly the rotors, and changing the backs, on the invoice they wrote that the fronts had 20% left in them, and the rears had 70%. I changed the fronts when they started making noise, which was probably a month after that, and I think that was in October. I could definitely believe it was a pebble making that noise, in fact, I initially thought there was a pebble stuck between my rim and my hubcap. I've also had my parking brake seize on me twice, though I never really noticed apart from the startling inability to park facing upwards on a hill. I assumed that the parking brake just had a lifespan like my air conditioner and that I'd have to get it fixed every once in awhile. Could the parking brake be making that noise?
#9 scwmcan
scwmcan
  • Regular Members
  • 723 posts
  • Gender:Male
Posted 10 June 2011 - 05:56 AM
if you had 70 % left last fall it is unlikely to be the rear brakes. not sure what it is since I can't hear it, but pretty sure it isn't your rear brake shoes.
Scott Martini
2005 Fortwo Passion Cabriolet
#10 Mike T
Mike T
  • Directors
  • 28,906 posts
  • Gender:Male
Posted 10 June 2011 - 06:26 AM
Feel the brake drums after a ride, are they hot?
#11 Squeeakers
Squeeakers
  • Regular Members
  • 124 posts
  • Gender:Female
Posted 10 June 2011 - 06:31 AM
I'll check when I get home tonight.
#12 frankie5string
frankie5string
  • Regular Members
  • 89 posts
Posted 14 June 2011 - 08:35 AM
Really ? Change the rear brakes with the front? That's the silliest thing I've ever heard. The front brakes do nearly all the slowing work. Rear breaks are mainly there to hold the vehicle once stopped. You can burn up rear drum brakes really easily if you fiddle with them so they're doing more work.That said, I know of one wise-a$$ who thought he'd "tweak" the rear drum brakes to increase their usage... His car would jerk to a stop every time he used the brakes because the drums were grabbing and latching. Not to mention he eventually delaminated the rear brake pads and required replacement... at 30000k... ;-)
Cheeri'o...
Frank...
#13 Squeeakers
Squeeakers
  • Regular Members
  • 124 posts
  • Gender:Female
Posted 20 June 2011 - 04:58 AM
Hey Mike T, thanks for suggesting that. It was really very informative. I checked my rear brakes after driving home and they both were fine. However, I managed to convince someone to hang out my passenger window while I drive around at speed to see if I could get any more information, and I discovered that it is NOT the rear wheels that the noise is coming from, but in fact it's the front right one. I checked it out when we stopped and the front right wheel was extremely hot, while the front left was cool.Any thoughts on that? The rotor's edge is quite crusty, could it be crud stuck in there somewhere? Caliper stuck? Something else entirely?
#14 scwmcan
scwmcan
  • Regular Members
  • 723 posts
  • Gender:Male
Posted 20 June 2011 - 05:31 AM
Hey Mike T, thanks for suggesting that. It was really very informative. I checked my rear brakes after driving home and they both were fine. However, I managed to convince someone to hang out my passenger window while I drive around at speed to see if I could get any more information, and I discovered that it is NOT the rear wheels that the noise is coming from, but in fact it's the front right one. I checked it out when we stopped and the front right wheel was extremely hot, while the front left was cool. Any thoughts on that? The rotor's edge is quite crusty, could it be crud stuck in there somewhere? Caliper stuck? Something else entirely?
my thought would be the caliper not sliding properly, and may have worn your pads out again, or it could be some thing stuck between the rotor and the sheild (reported here failrly commonly) either way the only way to be sure is take the front wheel off and inspect the brakes, also make sure to try and move the wheel (checking for bearing wear etc). good luck
Scott Martini
#15 Squeeakers
Squeeakers
  • Regular Members
  • 124 posts
  • Gender:Female
Posted 20 June 2011 - 06:55 AM
Thanks scwmcan, we'll check all that. God I hope it's not the bearings, they've already been replaced once, as well as the mount and rim, and some other part that cost a fortune that I can't remember the name of.
#16 scwmcan
scwmcan
  • Regular Members
  • 723 posts
  • Gender:Male
Posted 20 June 2011 - 07:38 AM
well hopefully it isn't the bearing then, if it has been replaced already it is less likely at least. Sticking caliper or debris is the most likely, hopefully nothing to serious.
Scott Martini
#17 Squeeakers
Squeeakers
  • Regular Members
  • 124 posts
  • Gender:Female
Posted 21 June 2011 - 05:50 PM
Ok, we got the wheel off to take a look at it. It had a lot of rusty gunk on the rotor edge, plus gunk under the brake pad. We got most of that off, and it's changed the way it sounds, but it looks a lot like I need to replace the rotor. I think it's warped slightly. I've figured out how to get them off, but I could use some help with finding new ones. I assume there's a specific size and/or type of rotor I need? Are there any great places to get them at a good price? Also, it looks like on the evilution site that the caliper bolts will need a torx socket, is that right?
#18 lebikerboy
lebikerboy
  • Regular Members
  • 2,033 posts
  • Gender:Male
Posted 21 June 2011 - 08:51 PM
Well, sort of... http://www.fq101.co....s-and-pads.html
[color="#8B0000"]2006 Lite White Pure , X-Gauge and tach, Corelines with Vredestein Quatrac 3 175/195, LED side markers, stubby antenna, embroidered luggage cover, Bosch 3300 filter, M20 spin-on adapter, Rotella T-6 5W-40 , Mann cabin filter, blind spot mirrors, old style cup holder, K&N E-9257 air filter, Michalak air sucker, chicken head fuel cover badge, 135 dB "Freeway Blaster" horn, , Optima Red Top 34/78 battery, Flying Tiger cdi remap, custom seat covers, 451 Brabus "Euro" softtouch shift knob, Michalak mirror/door covers, custom 450 cdi badges, custom license frames, aluminum pedal covers, 17mm wheel bolts with covers, rear view mirror adapter, LED 3rd brake light, "GT Sport" stainless exhaust, RS stainless valance, Eibach Pro springs, Vortex Generators.
#19 Speedie
Speedie
    Former Chief cook and bottle washer
  • Administrators
  • 6,829 posts
Posted 21 June 2011 - 09:45 PM
Rotors from the dealer are not that bad - about $80 bucks or so trade price - the tolerance for wear is not much so turning the rotor if it is worn at all is not a good idea. Fast Eddy can set you up with EBC pads. Here is a link to how to change the pads and rotors - Them's the Brakes Cheers, Cameron
"Lucy" 2006 Passion - Ruby Red - sunroof - black tridion
"NuBlu" - 2006 Pulse - Star Blue - black tridion - in need of some TLC
1994 Jeep YJ
1990 Dodge D250
#20 scwmcan
scwmcan
  • Regular Members
  • 723 posts
  • Gender:Male
Posted 23 June 2011 - 08:01 AM
Parts source actually has them (from their premium line if that means anything) for $40.75 each brake pads $45 for a set haven't tried them so not sure or place of orgin or quality though. I noticed NAPA has some as well (not sure on pricing on those though). It seems that parts are now (finally) becoming available from third parties, of course the quality may differ from OEM (as with any other make as well). I have found that there are now oil filters available easily too (though sometimes they are more than the dealer will charge so make sure you check prices from the dealer before you buy).
Edited by scwmcan, 23 June 2011 - 08:04 AM.
Scott Martini
#21 Squeeakers
Squeeakers
  • Regular Members
  • 124 posts
  • Gender:Female
Posted 29 June 2011 - 01:58 PM
It turns out the squealing noise was none of the above! It's still at MB right now for an epic 3 day fix, the squealing, the A/C and changin the tires. Turns out the squealing was a piece of plastic cover stuck in a something. Apparently not all that expensive of a part. I'll update once I get the paperwork back.
