@  dank1945 : (27 June 2016 - 08:03 AM) Check/clean connector #2 on the SAM unit. Actually, clean all connectors and read my post "Cranking without start, onbe more case".
@  dmoonen : (16 June 2016 - 12:31 PM) Is it getting fuel? If not its most likely a dead SAM connection.
@  Eclectrix : (16 June 2016 - 11:55 AM) My smart car won't start. 2006 Passion. The mechanic is sort of at a loss. It turns over but it won't go. Are there any problems inherent that he should look for?
@  Eclectrix : (16 June 2016 - 11:50 AM) eclectrix
smart electric - cost to recharge battery
  • Please log in to reply
4 replies to this topic
#1 sujim
sujim
  • Regular Members
  • 16 posts
  • Gender:Male
Posted 27 August 2011 - 05:04 PM
I was just wondering what kind of cost would be associated with recharging these little beauties. My hydro at this point is around $300 a month and I live about an hour and a half from the larger cities. Hydro keeps saying that we have to conserve and every time we get our hydro bill down a bit they raise the cost of hydro for one BS excuse or another.
#2 Huronlad
Huronlad
  • Regular Members
  • 3,458 posts
  • Gender:Male
Posted 27 August 2011 - 06:38 PM
If you are asking about the ED about $2 for a full charge for about 135 km of range. A/C uses up about 5% of the available charge, heat much more.
"Kalliste" 2005 Bay Grey Pure, tach/clock pods, panoramic roof, a/c, soft touch, ignition free windows, vertical wipers, Euro turn signals, LED fog lights, LED turn signal side marker lights, Scanguage II, LED interior light, LED license plate lights, LED reverse lights, LED high brake light, UWC wheel covers, tinted windows, Wet Okole seat covers with carbon fibre heaters, under seat drawer, EBC brakes and rotors, Eibach and Boge suspension, Stebel air horn.
"Labeeba" 2011 metallic silver Pure, tach/clock pods, A/C, arm rest, Design 1 alloy wheels, fog lights, all panels colour matched, heated seats, storage bin, oem storage cover, Area451 cruise control, Ultra Gauge, Team Dynamic Smartie 16" x 7.5" wheels, Yokohama S-Drive 215/40R16 tires, resonator box deleted.
#3 smartzuuk
smartzuuk
    Secretary, CsC Board of Directors
  • Directors
  • 6,987 posts
  • Gender:Male
Posted 28 August 2011 - 10:41 AM
I've tried to find out the kWh required to bring a battery from 80% drain to full recharge - no luck thus far. I think $2.00 is a bit light - that would mean (in BC at 9 cents kWh) about 22 kWh, or an old 100 watt bulb running for 220 hours...What we really need is the kWh, then you can figure out the cost. May depend on time of day in some regions.Like all driving, you can make this number smaller by driving conservatively. All the same principles apply - your ability to anticipate traffic flow, your speed, losing weight in the city, tire pressure..... it will all make a difference.
Order the ScanGauge II at http://www.efficiencymatters.ca
#4 Huronlad
Huronlad
  • Regular Members
  • 3,458 posts
  • Gender:Male
Posted 28 August 2011 - 04:34 PM
The production version for 2013 has a capacity of 17.6 kW.
#5 smartzuuk
smartzuuk
  • Directors
  • 6,987 posts
  • Gender:Male
Posted 28 August 2011 - 08:15 PM
17.6 kWh? Wow.... Well, then I guess the car will cost well under $2.00 to recharge in BC. Especially if you can get this within your cheaper rate of under 7 cents/kWh (limited to 1450 kWh per two month period per account - if you use more than this, it becomes closer to 9 cents). Rates outside of BC can be much higher, so perhaps that is where the $3.50 came from that the guys on the smart electric drive tour are quoting. Have a look at the US EPA rating sheet here: http://en.wikipedia...._electric_drive I like how kWh/100 km (or kWh per 100 miles) is used in the ratings. I would think this is the standard, but I've never been up on electric vehicle geekery... The EPA lists the smart EV as 87 mpg (US) equivalent. And the car is way heavier. Here's a bit of a primer I found on decoding the ratings for electrics: http://www.edmunds.c...ic-car-mpg.html
