@  Th3Guardian : (23 July 2016 - 03:55 PM) Wondering if anyone has a performance exhaust for a 451 in Ontario
@  BabyBenz : (23 July 2016 - 03:03 PM) Shuanghuan Noble
@  BabyBenz : (23 July 2016 - 03:02 PM) Came across an interesting article about a Chinese auto manufacturer that cloned the Smart Fortwo - was sued for copyright infringement but the suit failed.
@  smartzuuk : (21 July 2016 - 11:20 AM) no bites yet on the canada1.... it's still at 98,xxx kms with brand new tires and if someone is interested, let me know.... because if the Volvo goes first, the smart will come off the chopping block
@  Nigel : (19 July 2016 - 03:45 PM) Talk to Glenn smart142. I know he has been in contact with another welder about repairing stock mufflers.
@  Mike T : (19 July 2016 - 01:21 PM) Does Eddy in BC have a decent used one?
@  BabyBenz : (19 July 2016 - 12:44 PM) Trying to decide whether to pull the trigger on expensive muffler replacement at Mercedes or try and have an exhaust shop make a hopefully cheaper custom replacement.
@  Henry : (14 July 2016 - 03:13 PM) Carrot river is in north east Saskatchewan.
@  Henry : (14 July 2016 - 03:12 PM) Ya the cruise helps a lot. i have taken my smart as far east as Carrot river and as far south as palm springs. Quite comfy for the driver but the passenger doesn't get a reclining seat.
@  Mike T : (14 July 2016 - 06:29 AM) Yup. Top tip: Get cruise control, if you don't already have it.
@  Surturiel : (14 July 2016 - 06:09 AM) hmmm... So, just the usual (change oil, check everything), cram the car full of junk and head for 8 days of road?
@  smartzuuk : (14 July 2016 - 04:47 AM) It won't change things enough to matter... I've driven all the way from BC to Labrador and return on the stock wheels and tires....
@  Surturiel : (13 July 2016 - 11:48 PM) Should I put on wider wheels for the trip? would that make it more bearable? (roadster steelies+conti procontacts)
@  Mike T : (13 July 2016 - 06:18 PM) No problem. I did Toronto to Vancouver Island in 4 days!
@  Surturiel : (13 July 2016 - 05:01 PM) question: I *might* move from Vancouver to Halifax, and was thinking about driving all the way there with my 450. Stupid or REALLY stupid idea?
@  Surturiel : (13 July 2016 - 05:00 PM) hey, everyone
@  Mike T : (11 July 2016 - 08:10 PM) me too
@  dmoonen : (11 July 2016 - 04:59 PM) So I've totally missed updating my bike totals haha
451 Headlights
  • Please log in to reply
16 replies to this topic
#1 Pretty in Smart
Pretty in Smart
  • New Members
  • 8 posts
  • Gender:Female
Posted 06 January 2013 - 06:31 AM
Hello:My 2008 passion's headlights constantly burn out. When one side goes and it's replaced, within weeks the other side goes as well. I've been told it's a common problem, however they burn out so often that it's about every 6 months I'm changing the bulbs. Anything I can do or change to at least keep the bulbs going for longer so they don't drain so quicly? Just seems a little ridiculous to have burnt out bulbs that frequently.
Pretty in Smart
#2 fordnut71
fordnut71
  • Regular Members
  • 554 posts
  • Gender:Male
Posted 06 January 2013 - 07:17 AM
some have had luck buying bulbs from truck stops as they are a long life an take a lot of shaking.
#3 Lito
Lito
  • Regular Members
  • 479 posts
Posted 06 January 2013 - 10:34 AM
I'll be keeping an eye on this thread, as I experienced 3 burn lights since I bought the car just a little while back. One was a plate light and was replaced during a schedule service together with a headlight, but the third was a front parking light after the service, so I bought LEDs to replace the pair. Regrettably I don't think that there would be LED options for headlight high-low beams.As other lights let go (back lights for example) I will replace with LEDs.
Edited by Lito, 06 January 2013 - 10:34 AM.
Lito
2009 451 Pure w/ac
#4 David_18
David_18
  • Regular Members
  • 970 posts
  • Gender:Male
Posted 06 January 2013 - 10:54 AM
If you can understand, you can find the solution here :P http://www.clubsmart...;p=84459#p84459
#5 Lito
Lito
  • Regular Members
  • 479 posts
Posted 06 January 2013 - 11:20 AM
err... My French is as good as my Cantonese, but google is my friend (sort of)...
Go to your dealer and ask for the kit resistances for the front headlights. I got free from Three Rivers Mercedes while I was only going to buy bulbs H7 better. I mentioned to the clerk's desk I spent several bulbs in a year. He then proposed the amendment without charge. He is son of two resistors that are incorporated slightly lower the voltage going to the bulbs. No visible use. Easy to install, although to make it free, they must be installed at the dealership.
The kit was installed in August and I have not burned blister since. Under normal circumstances I would have spent at least 2 ...
The part number for this kit is 451540 June 23 (ts el cable set). There is probably a service bulletin over there ...
So, as I understand it, dealers can supply some sort of adapter with a resistor, which lowers the voltage going to the bulb, without marked effect on the light output, which prevents early burnouts. Is this correct?
Lito
2009 451 Pure w/ac
#6 Mike T
Mike T
  • Directors
  • 29,129 posts
  • Gender:Male
Posted 06 January 2013 - 11:28 AM
I would not want to lower light output at all. Just get LL (long life) bulbs.
#7 David_18
David_18
  • Regular Members
  • 970 posts
  • Gender:Male
Posted 06 January 2013 - 11:42 AM
Yes Lito ! Mike, the light output is supose to be the same.
#8 Huronlad
Huronlad
  • Regular Members
  • 3,471 posts
  • Gender:Male
Posted 06 January 2013 - 11:47 AM
The wiring is standard on the newer cars(2011 on or something like that). Original headlights in my 2011, 34k km and still going. Operation is better than the lights in my 2005.
"Kalliste" 2005 Bay Grey Pure, tach/clock pods, panoramic roof, a/c, soft touch, ignition free windows, vertical wipers, Euro turn signals, LED fog lights, LED turn signal side marker lights, Scanguage II, LED interior light, LED license plate lights, LED reverse lights, LED high brake light, UWC wheel covers, tinted windows, Wet Okole seat covers with carbon fibre heaters, under seat drawer, EBC brakes and rotors, Eibach and Boge suspension, Stebel air horn.
"Labeeba" 2011 metallic silver Pure, tach/clock pods, A/C, arm rest, Design 1 alloy wheels, fog lights, all panels colour matched, heated seats, storage bin, oem storage cover, Area451 cruise control, Ultra Gauge, Team Dynamic Smartie 16" x 7.5" wheels, Yokohama S-Drive 215/40R16 tires, resonator box deleted.
#9 Ofeu
Ofeu
  • Regular Members
  • 35 posts
  • Gender:Male
Posted 06 January 2013 - 04:18 PM
As David18 replied. Part number is 451 540 23 06. The kit consist of 2 resistive wires and 2 bulbs. Say that to your service advisor. Ask for his boss if he does not want to install it no charge. If not, go higher! There must be a service bulletin on that matter. It was installed on my car at no charge after stopping in a MB dealer in Trois Rivieres QC. I was just looking for more resistant bulb. Parts manager kindly offered to install that kit at no extra charge. Oh yes... I was out of warranty also...Patrice
Edited by Ofeu, 06 January 2013 - 04:20 PM.
#10 Lito
Lito
  • Regular Members
  • 479 posts
Posted 06 January 2013 - 05:50 PM
Found the following here
Why are my headlights burning out quickly?
Headlamp bulbs can be sensitive to higher system voltages on cars. There is a resistance kit (A 451 540 23 06) that can be installed to reduce the voltage on the headlamps and prolong their life. Headlamps with integrated resistors have been installed in production since December 2010.
No mention that this should be free from dealers, mind.
Lito
2009 451 Pure w/ac
#11 smartraja
smartraja
  • Regular Members
  • 25 posts
  • Gender:Male
Posted 06 January 2013 - 08:51 PM
Hello: My 2008 passion's headlights constantly burn out. When one side goes and it's replaced, within weeks the other side goes as well. I've been told it's a common problem, however they burn out so often that it's about every 6 months I'm changing the bulbs. Anything I can do or change to at least keep the bulbs going for longer so they don't drain so quicly? Just seems a little ridiculous to have burnt out bulbs that frequently.
My 2010 headlights is burn out a month ago and i take to TPM (Victoria Smart Dealer ) for replaced , i wait for 30 minutes and the manager told me everything already done and being replaced including the wiring so the bulb not gonna burn out fast in the future .. and they don't charge (free) for everything.
2010 Smart Passion Red/Black (Raja)
2011 GMC Terrain SLT-2 Onyx Black (Romeo)
#12 Mike T
Mike T
  • Directors
  • 29,129 posts
  • Gender:Male
Posted 06 January 2013 - 09:33 PM
Hmm, interesting! A soft warranty?
#13 smartraja
smartraja
  • Regular Members
  • 25 posts
  • Gender:Male
Posted 06 January 2013 - 10:00 PM
No idea Mike .. i didn't ask .. maybe is the warranty
#14 Mike T
Mike T
  • Directors
  • 29,129 posts
  • Gender:Male
Posted 06 January 2013 - 10:10 PM
Yeah like one of those "the customer complains - we act" type of situations. I've only changed my own bulbs so I guess I would never get a freebie like that!
#15 Lito
Lito
  • Regular Members
  • 479 posts
Posted 07 January 2013 - 08:24 AM
How many light bulbs does it take to change a Mike? :P
Lito
2009 451 Pure w/ac
#16 Pretty in Smart
Pretty in Smart
  • New Members
  • 8 posts
  • Gender:Female
Posted 10 January 2013 - 08:36 AM
Thanks Everyone! I'll speak to MB Midtown at my next servicing about the resistant kit.
Pretty in Smart
#17 AHZELA
AHZELA
  • Regular Members
  • 321 posts
  • Gender:Not Telling
Posted 10 January 2013 - 05:49 PM
Do yourself a favour if you can and goto downtown on dundas. (unless you purchased from uptown) More knowledgable and a ton more friendly. I just got bulbs tuesday, our go about every 6 months as well. I will have to get this kit.
05 CDI pulse Blue/Silver 205000k
Eibach Lowering springs
Turn signals relocated into Lens
Full EGR delete, with emulator
"Newish" Turbo installed by me.. Sept 2014
Re-Wired SAM to bypass part of N11
New to us 2011 Kia Sorento AWD... no mods.... yet!
