@  Mike T : (27 January 2016 - 01:03 PM) Get up stand up
@  SmartED : (27 January 2016 - 07:44 AM) "fall in"
@  Francesco : (26 January 2016 - 11:11 PM) "stand in"
@  Mike T : (26 January 2016 - 10:35 PM) "love in"
@  minifreak : (25 January 2016 - 10:55 PM) "teach in"
@  Mike T : (25 January 2016 - 07:28 PM) It's all in the name
@  cadillacman : (25 January 2016 - 06:47 PM) so is there an implication that people with ED's are having trouble getting it started ?
@  marchanna : (25 January 2016 - 06:21 PM) What about the glow plugs?
@  Mike T : (25 January 2016 - 04:27 PM) Duh they have electronic ignition
@  tolsen : (25 January 2016 - 03:56 PM) I've also been wondering if there is a good guide for replacing the points on an ED.
@  NelsonSmart : (25 January 2016 - 03:07 PM) What would a starter motor start on an ED?
@  Mike T : (25 January 2016 - 10:04 AM) Seriously?
@  tolsen : (25 January 2016 - 07:41 AM) Does the ED have a starter motor?
@  dmoonen : (23 January 2016 - 03:22 PM) Glenn should have one
@  Francesco : (22 January 2016 - 11:18 AM) the electric defrost element I mean
@  Francesco : (22 January 2016 - 11:17 AM) Yeah will check with Bernd tonight. I haven't yet checked the wires at the component, but I can tell you, ZERO heat from the element.
@  Mike T : (22 January 2016 - 07:17 AM) Get it from a European dealer....
@  Francesco : (22 January 2016 - 05:57 AM) In case anyone here was wondering, $385 in stock in Toronto. Yet another $10 part that smart thinks should cost 40x as much!
@  GRP151 : (22 January 2016 - 05:29 AM) See my latest post on key fob repair!
@  GRP151 : (22 January 2016 - 05:14 AM) key fob
@  Francesco : (21 January 2016 - 10:31 PM) Anybody know how much MB wants for the glow plug controller (aka "Pre-Glow Time Relay" or N14/2)?
New Uk Member
  • Please log in to reply
4 replies to this topic
#1 Grumpyb
Grumpyb
  • Regular Members
  • 20 posts
Posted 12 January 2014 - 09:52 AM
Hi , Im a UK Smart owner and I have a converted 08 Passion with a 25 cell Lifepo4 pack and HPEV AC30 motor/ Curtis controller.For a living I support UK Ev users and this came my way as a development mule for a UK company that subsequently made a series of converted Citroen C1s.I actually purchased two of these, but one was totalled in a road accident last year. I still have its remains waiting for an appropriate priced 451 non runner to convert. Having caught the Smart bug, I bought a 451 CDI (2010) that was repossed by the finance company. No keys, 44000miles and lots of general wear. My wrecked electric has provided the replacement worn interior. To sort the keys the UK smatrt dealers wanted around 800 to replace the SAM, keys, lots of special costs for computer codes from MB/ Smart and 120 per hour to do the work. So I shopped around and the formal solution is the Smart one, as you have to have one key for the star diagnostics to programme another. However a nice clever Romanian has worked out how to get around it. And apart from a genuine remote a UK locksmith company who has the computer and kit, charged me 65 to programme one key fob. What a result. The car transmits a code, the key fob responds in a certain way, the std system allows codes to be adrift by a few numbers, to allow for you pushing the buttons away from the car and moving on from your code from the car. So they decode what the car is transmitting, using an algorithm they then create a non moving code chip to match. Put that to the key blade (Fortunately I had one of these) and the car now thinks its got an original key, you can then programme a new fob to the SAM. A brilliant piece of deduction. After a couple of uses of the fob the hard coded chip will no longer be any use but now you have a properly coded new fob.WIth the car functional, it then became obvious why the previous owner had defaulted, The turbo had seized and the shaft snapped. So I have a used turbo, but the original oil pipework was seriously clogged , I dont think they had ever serviced the vehicle. SO I dropped the sump and it was really dirty inside. I have fitted a sump plug, and having cleaned the worst of the muck out I ran flushing oil and a new filter through the engine, and replaced with nice fresh oil and filter. The car would not run for more than a few seconds. Diagnosis was a blocked particle filter. So off with the exhaust and out with the Oly acetylene burner, introducing heat and excess oxygen through the exhaust caused it to burn off the internal muck. More to come the EGR mixing system was almost blocked with greasy gunge, this was cleaned out but the car still goes to limp mode after a couple of minutes. Codes being P1408 and P1409. TAke out the vacuum EGR valve itself, it was not opening at all. Swapped for a clean one but I still have P1408. The moral of this, if the deal looks too good to be true, then it probably is too good to be true. I wish I hadnt strayed from my Electric vehicles, but I do need one that will go a few hundred miles.Any thoughts on P1408?Grumpy-b
Edited by Grumpyb, 12 January 2014 - 09:55 AM.
#2 Mike T
Mike T
  • Directors
  • 28,900 posts
  • Gender:Male
Posted 12 January 2014 - 10:16 AM
Welcome, that's quite the story, I've no idea about the code though.
#3 turbomar
turbomar
    Get Er Dun!
  • Regular Members
  • 555 posts
  • Gender:Male
Posted 12 January 2014 - 10:28 AM
Welcome to the forum! Could you elaborate on the EV mod including pics in the EV section
#4 Grumpyb
Grumpyb
  • Regular Members
  • 20 posts
Posted 12 January 2014 - 10:52 AM
I didnt put a comment in the EV section as it appeared to be on the Smart /MB v3 rather than conversions.But I will put something on there in the near future.Grumpy-b
#5 josh9120
josh9120
  • Regular Members
  • 69 posts
  • Gender:Male
Posted 13 January 2014 - 04:41 PM
Welcome to the club
'05 Passion Coupe
