Full Version: firewall pass through
Club smart Car > Technical Discussions > How-To: 450 Model, 2005-2006, diesel
gordo.bernard
Behind the fuse panel is a rubber grommet where a main wiring harness goes through the "firewall". This grommet has a couple of different sized nipples. Choose the one that will match your wire and snip off the tip with some side cutters and feed your wire through.
Click to view attachment
After it is fed through, you will find it behind the driver's headlight and behind the radiator overflow tank.
Add a blob of grease or sealer and your all set.
bilgladstone
Excellent. Thank you, sir!
