SMRT EH Posted February 19, 2008 Posted February 19, 2008 I have found these troublecodes a I think all PO codes are the same for all cars. PO100 Volume Air Flow Circuit Malfunction PO105 Barometric Pressure circuit Malfunction Po107 Map Sensor Voltage Too low PO108 Map Sensor Voltage Too High PO110 IAT Circuit Malfunction PO112 IAT Sensor Voltage Low PO113 IAT Sensor Voltage High PO115 ECT Circuit Malfunction PO117 ECT Sensor Voltage too Low PO118 ECT Sensor Voltage too High PO120 Tp Sensor Malfunction PO121 Tp Sensor Fault PO121 TP Sensor Voltage Does not agree With MAP(m/t) PO122 TP sensor Reference Signal Voltage Too low PO123 TP sensor Reference Signal voltage too high PO125 Closed Loop Temperature Not Reached(m/t) PO125 Excessive Time To Enter Closed loop fuel Control PO130 o2 Sensor Circuit Malfunction (Bank 1 sensor 1) PO131 Upstream HO2S Voltage grounded PO132 Upstream HO2S Shorted to Voltage PO133 Upstream HO2S Response (m/t) PO134 Upstream Ho2S stays at center PO135 o2 Sensor Heater Circuit Malfunction (bank 1 Sensor 1) PO136 o2 sensor circuit malfunction (Bank 1 sensor 2) PO137 Downstream HO2S Voltage Grounded PO138 Downstream HO2S Shortage to voltage (m/t) PO139 Downstream HO2S Stays at center (m/t) PO141 Downstream Ho2S Heater Failure (m/t) PO141 o2 sensor heater Circuit Malfunction (Bank 1 sensor 2) PO170 Fuel Trim Malfunction PO171 Fuel System to lean PO171 Fuel System to Rich PO201 Injector #1 Control Circuit PO202 Injector #2 Control Circuit PO203 Injector #3 Control Circuit PO204 Injector #4 Control Circuit PO220 Fuel Pimp Relay Control Circuit PO300 Mulitiple Cyliner Misfire (m/t) PO301 Cylinder #1 Misfire PO302 Cylinder #2 Misfire PO303 Cylinder #3 Misfire PO304 Cylinder #4 Misfire PO325 Knock Sensor #1 Circuit PO335 No Crankshaft Reference Signal At PCM PO335 CKP Sensor Circuit Malfunction PO351 Ignition Coil #1 Primary Circuit PO352 Ignition Coil #2 Primary Circuit PO340 NO Cam Signal at PCM PO340 CMP Sensor Circuit Malfunction PO400 EGR Flow Malfunction PO401 EGR System Failure PO403 EGR SOlenoid Circuit PO411 Too little or To mcuh secondary Air(m/t) PO412 Pulsed Secondary air injection solenoid circuit(m/t) PO420 Catalyst Effiecncy below threshold (bank 1) PO422 Cataltic Converter effiency failure PO440 Evaporative Emission control system malfunction PO441 Evaporative Purge Flow Monitor Failure PO442 EVAP Leak Monitor Small Leak detected PO443 EVAP Solenoid Circuit PO443 EVAP COntrol System Purge Control Valve Circuit Malfunction PO455 EvAP Leak Monitor Large Leak Detected PO500 No Vehicle Speed Sensor Signal/Sensor Malfunction PO505 Idle air/control Motor Malfunction PO510 Closed Throttle Position switch PO551 Power Steering Pressure Switch Failure (m/t) PO605 INternal Controller Failure PO605 PCM Failure-SPI Communications PO700 Transmission Failure PO700 EATX COntroller DTC Center PO705 Transaxle Range sensor Circuit Malfunction PO710 Transaxle Fluid Temparture Sens Can anyone tell me for sure that these codes are for our Smart fortwo? Quote
SmartieParts Posted February 19, 2008 Posted February 19, 2008 If you are in the USA or Canada and speaking of the new 451 model (2008+) then it will comply with US OBD standards. - Steven Quote
SMRT EH Posted February 22, 2008 Author Posted February 22, 2008 If you are in the USA or Canada and speaking of the new 451 model (2008+) then it will comply with US OBD standards.- StevenWhat I am trying to say is I think these codes are the same for all cars. From what I was reading all PO type codes should be the same. I was hoping other owners, with OBD readers could verify if these codes are all the same? Quote
ValgardForkbeard Posted February 22, 2008 Posted February 22, 2008 I was hoping other owners, with OBD readers could verify if these codes are all the same?I have an OBD reader (a scanguage), but I hope that I will never have to verify that any of the codes are the same (that would mean that something was wrong).There is an industry standard list of codes that the auto manufacturer uses. They do not have to use all of them, and if they have their own, there are some of the codes available for that. (second character 0 for generic code, 1 for manufacturer defined.) I found a good web site to explain it all at OBD Codes.comMG Quote
stellair Posted July 13, 2008 Posted July 13, 2008 Any idea what a "P0087" code is? I'm experiencing sluggish performance and this code is showing on my scanguage. I've recently changed the fuel filter to try and correct, but the code continues to appear after clearing all codes....Ken Quote
Gent Posted July 13, 2008 Posted July 13, 2008 (edited) When a diesel pickup gets that code, it's low fuel pressure - often due to a leaking injector (if its not the filter).edit for clarification, and more codes:P000f-fuel System Over Pressure Relief Valve ActivatedP0016-crankshaft/camshaft Timing Misalignment - Bank 1 Sensor 1P0031-o2 Sensor 1/1 Heater Circuit LowP0037-o2 Sensor 1/2 Heater Circuit LowP003a-turbocharger Boost Control Module Position Exceeded Learning LimitP0046-turbocharger Boost Control Circuit PerformanceP0049-turbocharger Turbine OverspeedP006e-turbocharger Boost Control Module Supply Voltage Circuit LowP006f-turbocharger Boost Control Supply Voltage Circuit HighP0071-inlet Air Temp Sensor Rationality - EcmP0071-ambient Air Temperature Sensor Performance (tipm)P0072-inlet Air Temp Sensor Voltage Too Low - EcmP0072-ambient Air Temperature Sensor Circuit Low (tipm)P0073-inlet Air Temp Sensor Voltage Too High - EcmP0073-ambient Air Temperature Sensor Circuit High (tipm)P007c-charge Air Cooler Temperature Sensor Circuit LowP007d-charge Air Cooler Temperature Sensor Circuit HighP007e-charge Air Cooler Temperature Sensor Circuit Intermittent/erraticP0087-fuel Rail Pressure Too LowP0088-fuel Rail Pressure Too HighP00af-turbocharger Boost Control Module Performance Edited July 13, 2008 by Gent Quote
MikeT Posted July 13, 2008 Posted July 13, 2008 "Fuel Rail Pressure Too Low".Could be a bad fuel lift pump, bad high pressure pump, bad pressure regulator? Quote
Guest kwaldron Posted July 13, 2008 Posted July 13, 2008 What a coincidence. Mine through three of these today on the way home from the Niagara Cruise. Worse than limp mode. It's just dead mode. Quote
Speedie Posted July 14, 2008 Posted July 14, 2008 (edited) Sticky Regulator mayhaps - pretty common on some other CDI's - try running some injector cleaner. If not it is not a biggy to get at - but I imagine it will be the typical big $ to buy.The regulator lives near the edit - my bad - fuel pump side - picture was upside down! - the thingy with the tubes coming out of it that run to the fuel cooler. Pressure sensor is right next door.Cheers,Cameron Edited July 14, 2008 by Speedie Quote
bilgladstone Posted July 14, 2008 Posted July 14, 2008 Full set of OBDII codes you can download and save for reference.OBD_II_Codes.pdfCheers,Bil Quote
bilgladstone Posted July 14, 2008 Posted July 14, 2008 "Fuel Rail Pressure Too Low".Could be a bad fuel lift pump, bad high pressure pump, bad pressure regulator?... Obstructed fuel filter? Quote
MikeT Posted July 14, 2008 Posted July 14, 2008 ... Obstructed fuel filter?I think that had already been changed..... Quote
bilgladstone Posted July 14, 2008 Posted July 14, 2008 Oops; you're right. Didn't read carefully enough! Quote
stellair Posted July 14, 2008 Posted July 14, 2008 Thanks for all your responses. I'll start with the fuel injector cleaner because it sounds like the cheapest option. I've been burning biodiesel B20 through B100 for most of the last 100,000 klm and B100 for the last two months so I suspect the components are shining like the teeth of Crest tootpaste sponsor. (This is not an endorsement for Crest toothpaste. Seek independant council before brushing your teeth ) Cheers,Ken Quote
stellair Posted July 17, 2008 Posted July 17, 2008 I had the changed the E.G.R. value ($600+) and the P0087 and P0401 cleared up. Quote
bilgladstone Posted February 22, 2009 Posted February 22, 2009 P0071-inlet Air Temp Sensor Rationality - EcmWhat the heck is that?????????????How's your air filter?B Quote
bilgladstone Posted February 22, 2009 Posted February 22, 2009 (edited) I've read on SCoA that the 451's gas engine is... sensitive... even to mild obstruction of its air filter Edited February 22, 2009 by bilgladstone Quote
fortow Posted February 23, 2009 Posted February 23, 2009 Full set of OBDII codes you can download and save for reference.OBD_II_Codes.pdfCheers,Bil Are those codes for the diesel or the gas engine or both? Quote
bilgladstone Posted February 23, 2009 Posted February 23, 2009 Are those codes for the diesel or the gas engine or both?Yes This is a universal TC list Quote
MikeT Posted February 23, 2009 Posted February 23, 2009 (edited) Man I feel left out, 113,000+ km and no DTCs (yet)! Edited February 23, 2009 by Mike T Quote
