Rubus Posted May 3, 2008 Posted May 3, 2008 Hi There,My Smart has ~55,000 km and I am wondering when I can expect to have to replace the brakes? Cheers,Peter. Quote
jackblack Posted May 3, 2008 Posted May 3, 2008 77,000 km and I'm now ready to change them for the first time Quote
Speedie Posted May 5, 2008 Posted May 5, 2008 Really depends a lot on the type of driving you do and how you drive - lots of city miles and a heavy brake foot - you will be good to get 50k - if you do more highway and use the gas pedal and shifter more than the brake pedal - 70-80k should be about right. If you get the car serviced at the dealer they are supposed to write down the remaining % of pads on the service report. If you are a DIY type - you can see the thickness of the pads by droping a wheel off.Mind you my Jeep still has the same rear drum shoes at 240k - would have the same front pads if they hadn't made the rotor really soft and the pads really hard.Cheers,Cameron Quote
FlyingTigerDevelopment Posted May 5, 2008 Posted May 5, 2008 Make sure to check the right front inside pad. Quote
Duck Posted May 11, 2008 Posted May 11, 2008 Had my front pads done at 161 000 km. They lasted a LONG time! -Iain Quote
Speedie Posted May 13, 2008 Posted May 13, 2008 But Duck - you are noted for never using your brakes - just the pedal beside them Cheers,Cameron Quote
CanadianTurbo Posted May 13, 2008 Posted May 13, 2008 I changed mine at 46,000 kms, they were not too bad but went to some EBC Greens and new rotors too, still breaking them in, but looking forward to lower amounts of dust thats for sure. Quote
asmart42 Posted May 13, 2008 Posted May 13, 2008 I just changed the front brakes. Heard a noise in the front end. It was the brake sensor (metal plate) warning that the brakes are almost finished.Just under three years young and 108,900 Km on the car.Live in the country, so most are Highway km's.Only changed the pads as the rotors were in good shape.Super easy to do yourself for a total cost of $69.00 for Mercedes pads. Quote
F1 Whore Posted May 29, 2008 Posted May 29, 2008 My front brakes were just replaced, I was told I had about 10% of the pads remaining.I've got just over 52,000 km on my car. Quote
MikeT Posted May 29, 2008 Posted May 29, 2008 (edited) My inner pads were detached (rusted off) the backing plate at 85,000 km. I otherwise might have got 100,000 km from that set. Edited May 29, 2008 by Mike T Quote
robm Posted August 4, 2009 Posted August 4, 2009 Make sure to check the right front inside pad.my RH front brakes have just gone noisy. why is it the RH inside pad?R Quote
MikeT Posted August 4, 2009 Posted August 4, 2009 Inside because that's the side the piston pushes on and RH side due to road camber/weight transfer during braking. Best to change them ASAP..... Quote
FlyingTigerDevelopment Posted August 4, 2009 Posted August 4, 2009 my RH front brakes have just gone noisy. why is it the RH inside pad?RYou will have to ask an engineer from smart on this one. I had some thoughts; but didn't spend the time to confirm. I think it is due to heat. The curb side and being inside of the rotor provide minimal cooling. The extra heat would be a good reason to cause the pad adhesive de-lamination. Probably similar reason for the added wear. This is just an educated guess. Quote
robm Posted August 7, 2009 Posted August 7, 2009 (edited) You will have to ask an engineer from smart on this one. I had some thoughts; but didn't spend the time to confirm. I think it is due to heat. The curb side and being inside of the rotor provide minimal cooling. The extra heat would be a good reason to cause the pad adhesive de-lamination. Probably similar reason for the added wear. This is just an educated guess.just changed my pads and discs on my 05 cdi at only 52000 km. The RH inboard pad was delaminated. In hindsight I should have know it was this..the noise came on all of a sudden about 5 minutes after I had a semi panic stop to avoid someone backing on the the highway.R Edited August 7, 2009 by robm Quote
