MikeT Posted November 21, 2022 Author Posted November 21, 2022 Sunday I made up and installed the following brake lines with metric-nutted fittings (11 mm): firewall to front splitter front splitter to LF wheel front splitter to RF wheel rubber hose on torque tube to rear proportioning valve rear proportioning valve to LR wheel rear proportioning valve to RR wheel The only metal line not remade now is the long one that goes from front to rear, and so it's the only one with 3/8" fitting nuts. Just for symmetry and to have a coherent set of nuts I think I will do it too. Then check tightness and attempt a bleed. No photos this time as it's kind of dull viewing Quote
MikeT Posted December 22, 2022 Author Posted December 22, 2022 Today I received the oil pressure sending unit for my Jaeger sports instrument panel. This will be used sometime in the future, after the car is on the road and proven to be reliable. Quote
MikeT Posted December 22, 2022 Author Posted December 22, 2022 I received the license plate light last week.... Quote
MikeT Posted December 22, 2022 Author Posted December 22, 2022 Got a bunch of parts for cheap at an auction in the eastern USA, which someone from back there will deliver to me in Seattle in June: OE SEV windshield wipers OE 404C headlight rings (4) .... Quote
MikeT Posted December 22, 2022 Author Posted December 22, 2022 Mirrors and late model 404C driving light trims All of the foregoing stuff from the auction was $60. One headlight ring costs 100 Euros in Europe! Quote
MikeT Posted July 22, 2024 Author Posted July 22, 2024 December 2022: The Carello 404 Coupé license plate light arrived today. Minty new. It cost me 95 Euros including postage to Canada from Italy. Actually the seller paid 26.90 EUR for the postage! There was something rattling around inside the package, which was inside the light - see the 3rd photo for details of what it was. Jan 2024: April 2024: My son using the tool to press piston #2 in. Finally got the bottom end assembled. Checked all clearances with Plastigauge, good to go. Next step is timing and head. Need to get my special zinc lube from Amazon before that happens. July 7: The other belts I have. The three reddish-brown ones are original used belts. Botton left is the original from my car. Bottom right is one bought in Australia in 2009, so pre-reproduction era. Bottom left will likely be going in and the bright white one will come out. July 21: First photo is a comparison of the Peugeot Classic reproduction, which is known to be fragile, to the EAI (Australia) supplied belt that I bought in 2009. Left is the repro and right is the EAI belt. The Rilsan plastic is a bit lighter coloured on the repro and the reinforcing wires are golden coloured. The EAI one looks like the one Michel Aubé sent me a photo of. I initially test-mounted the best-looking of the used belts to the injection pump and once tightened up, the belt was overly loose and floppy. I therefore decided to use the EAI belt, which I think/hope is OEM. Bolted up the front cover, doing a better job of tightening the bolts so the cork gasket does not split! (The last time I found it had been compromised by excessive tightening.) Then the sump and now it's ready to receive the head. Quote
MikeT Posted July 24, 2024 Author Posted July 24, 2024 Forgot to bend the tab on the injection pump bolt so off the cover came a third time, bent tab, put it all back together Monday and NOW it's ready to receive the head.... Quote
MikeT Posted August 11, 2024 Author Posted August 11, 2024 (edited) Edited August 11, 2024 by MikeT 1 Quote
MikeT Posted August 19, 2024 Author Posted August 19, 2024 (edited) Today, it's back where it belongs. Edited August 19, 2024 by MikeT 1 Quote
MikeT Posted February 20, 2025 Author Posted February 20, 2025 Thanks for asking. After the 2021 assembly with the crap engine work by Anderson Precision Engines of Saanichton, the brakes had been assembled with an old booster and an unsuccessful bleed attempted. So for 3 years there have been empty or mostly empty brake cylinders and that is something I should not have left. So the cylinders are not in great condition - the rears in particular. I discovered this last weekend: So I've got to check the fronts - I hope they're better. Bottom line, more work on brakes and a bleed with a new booster after I've got usable cylinders. Then adjust the valves, do electrical checks and attempt a start. We've got a new Mercedes GLC 350e coming in April or May so that may attenuate the work and cylinder purchase schedule a bit, particularly if the front ones are all shot. I hope to have the 404C running later this year. Quote
lebikerboy Posted February 21, 2025 Posted February 21, 2025 It will be great to see the 404C in finished form. So I see you're going hybrid. Probably a better choice than an EQS at least, at this juncture. 1 Quote
MikeT Posted March 9, 2025 Author Posted March 9, 2025 New rear wheel cylinders arrived, just coated them with black Krylon and then greased under the end caps. Quote
MikeT Posted June 28, 2025 Author Posted June 28, 2025 Got the replated Peugeot OE brake line fittings today, 21 excellent ones (I think I need 18) and 5 OK-ish ones. I also had one last batch of stuff replated, including some KF2 hardware. One of the large nuts looked like Swiss cheese after being de-rusted and plated! Next step is to remake the brake lines again, and then I should be ready to try a start for the first time after the rebuild. Quote
MikeT Posted November 23, 2025 Author Posted November 23, 2025 Modified puck is a good lift for the 404C sills....I cleaned out the 4 front brake cylinders and reinstalled them a couple of weeks ago. I realised a couple weeks ago that the front crossover brake lines with bubble flares need a specific type of fitting. So I looked online... Sunday Nov 16 I made a couple of lines and then mounted them all to the car. New rear proportioning valve with two of the three lines connected to it... Third line connected to the prop valve. Longest line to the front mounted and the end will be flared under the car once I establish the perfect length. Front crossover lines and some other spare brake parts arrived from France Nov. 19. ALVEAS is a good fast supplier. So Alveas sent me lines with two different types of fitting. The upper one is correct.....according to my original fittings that can't be re-used.... ...so I made another that was identical to the correct one... Alveas correct line at the upper left; one I made with a Peugeot (but not 404) fitting on the upper right and below that, the one I made to replace the incorrect Alveas one which is at the bottom. RF wheel LF wheel The metal brake lines can all be removed and replaced with the engine in situ but it's not easy. I had to cut the rear line to the correct length (mm-perfect!) under the car and flare it there, and then connect it to the splitter with the splitter not yet mounted to the crossmember. That's because the steering rack in a LHD car will prevent access to the fitting nuts for tightening if it's on the X-member already. Cut the RF brake line under the car too and flared it there and that one can be mounted with the splitter on the X-member. The next step is to take the Hydrovac out and tighten the RF brake line on the splitter and mount the last metal line that attaches to the firewall. Then it should be ready to bleed. 1 Quote
MikeT Posted July 3 Author Posted July 3 Yeah but the unions still leak. Have to redo lines again.... Quote
