Water pump removal and install labour 2.40 hrs cost is $280.80water pump is $176.10belt ac $17.97v belt 21.75 antifreeze 22.75total =$519.37........................................Alternator replacement labour 1.60 hrs- $187.20alternator- $520.00total $707.20
Rocker arm replacementValve cover remove/instal, seal $149.25Hydraulic valve clearance adjusters All replace 9 CPS $3.20 $318.40Hydraulic element $17.80Rocker arm 2 at $27.40 = $54.80Screw @ $1.00 2 = $2.00Parts $163.60 Labour $467.65 Total 631.25
Turbo and intercooler replacement (7 Oct 2008)Turbo- $929.00Intercooler $396.50Intercooler carrier- $51.75Oil pipe-$87.15+ nuts, bolts, gasketsTotal parts- $1543.97 Labor- $485.10Total with taxes- $2296.82
Oil pump chain drive, partsoil pump chain- $102.55chain tensioner-$57.75pin- $9.47crank gear- $38.60total- $211.90
  • 1 month later...
Both front bearings replaced - $796.70 incl tax .....Wheel Bearings (Front) $162.50 (Each) Front pads and rotors - $358.
Edited by smart142
  • 1 month later...
from member bbz:rear bearings $660.52front bearings & related parts $796.70intercooler & related parts $1425.53ball joints & brakes $459.131 injector & related parts $1178.68a/c compressor & belt $1389.09
  • 4 weeks later...
Starter. Courtesy of Huronlad.005-151-38-01 starter - $415.000001785V000000000 clip - $0.83 Not sure what this clip is?Labour - $591.00Taxes - $130.89Total - $1137.72
  • 1 month later...
During a B service, the misfiring of the injector was identified. I've paid $66 plus tax for this moto check.The following week, I took my car for the repair (getting the injector cleaned). This is the cost breakdown:Injectors remove/install, replace if necessary: $110Short test perform: $22Perform fuel Quantity balance test: $55Perform de-carbonized fuel injectors: $88Total: $308
  • 3 weeks later...
From Duck:17.11.2008 211.138 Replace Intercooler $592.5017.11.2008 211.138 Replace Clutch Actuator $629.8017.11.2008 211.138 Replace EGR (Mixing Housing) $447.63
  • 2 months later...
Mercedes-Benz Rive-Sud (Greenfield park)- Last "B" maintenance = 303,48$- Clutch replacement = 2227, 89$ (Including clutch actuator, pilot bearing)- 2 front sealed beam (water infiltration) = 1613, 36$By myself- Complete front brakes + caliper lubrication = 237, 90$- Turbo charger = 1054, 12$ (including oil return pipe, manifold gasket, EGR gasket, stud and nuts)- Belts (A/C & Alt) = 43,68$- Alternator = 576,87$ (including belts replacement by the same time)
Oakville MBKey FOB's re-programed .5hr charged. $58 incl GST Incl a free loaner Smart for the day. (car has to stay there for 1/2 a day)
  • 2 weeks later...
Overseas Motors WindsorEGR Valve replaced - just under $600. Sorry, just looked at the receipt, it was just under $800!
Edited by Kent&Alex
  • 2 weeks later...
  • 1 month later...
:angry:RECENT QUOTES
Horn does not work
Replace entire SAM unit.
$981.00 plus labour.
Driver's door latch sticking.
Replace entire door latch.
$262.00 plus labour.
ABS light on. Rings on driveshafts are worn.
Replace entire driveshaft, both sides.
$788.00 for two driveshafts, plus labour.
Paint peeled off all four steel rims during first year. Repainted under warranty. After five years, 80% of paint gone.
Replace four rims.
$328 for four rims, plus balancing, stems and labour.
In this section post ONLY the repair cost- no banter or comments please!
  • 1 month later...
from smart65, 20 March 2010:driver's door latch at a cost of $271.70 for the part and $102 for 1 hour's labour, plus taxes
Victoria Star Motors Kitchener Ontario March 25 2010turbo charger 1024.00remove and install 129.95seal 5.64gasket seal 2.47gasket 1.32sealing ring 1.18clamp 3.93nut 1.91seal 4.44oil pipe 91.15screw 1.42loom tie 2.64Labour 274.45total repair $1430.53
Guest darth
Do you mind if I ask where you get serviced? I was quote $150 to run the Short test by Silverstar in Surrey.
  • 3 weeks later...
Mercedes Benz Oakville Autohaus - Oakville, Ontario
Coolant Flush - $156.05 ($132.60 + Antifreeze, 3.8 L)
Service B - $182.52 ($139.22 + Oil Filter, Oil, Air Filter)
  • 9 months later...
  • 4 weeks later...
  • 1 month later...
