Put on the summer rubber/original alloys (amazing how sore and crippled I've become since doing it this afternoon).William.... how much for your 451 cup holder?? Did you source it at MB London??
I ordered it from Wellsmart, I was dinged GST and a $5 service fee from Can Post, brought the total to about $75. The price should be about the same at MB.
I got mine from Flying Tiger. Good price, but I guess Eddy can't get a good deal on shipping. After shipping and GST, price was similar to what I'd have paid the local MB before GST/PST.
Just came back from a flogging test run in my smart, with MB Neighbour at the wheel. I cleared the P0238 code the other day, but he said the computer stores it and they'll be able to read it with the DAS. While they're slapping on a new turbo, they'll likely look into the EGR as well. He didn't like the sound of the alternator, so he asked if I'd had trouble starting. When I said only "only once or twice" he said I'll need a new alternator, too (and didn't mention the crappy OE battery). At the first stop sign, he addressed my perceived actuator or clutch issue: "Worn motor mount -- the engine is hitting the chassis." Finally, the pulsing brakes. He doesn't think the new EBC disks are warped or run out. He suggested I wait until they cool completely, then take off the alloys, turn them 1/3 (one bolt), and gradually re-torque the bolts 1/8 of a turn at a time. If the pulsing is still very evident, he suggests removing the rotors and checking for rust or dirt on the hubs -- though I swear I wire-brushed and cleaned the hubs prior to mounting them.
Sameguy:It sounds like you got some real good service advice about your car, from a REAL expert. It's too bad more smart car owners don't have access to 'your guy'!
Yep. And before I got it in 2007 he warned me not to, unless I wanted to get my hands dirty a lot and learn everyone's name in the Service Department. ;)
Pulled the rotors and polished the hub and rotor mating surfaces. Some noise is still there, as is a small amount of pulsing. On tire-swap day I cleaned out the rear drums and adjusted the shoes. They are not too tight, but while taking care of it I may have mixed the two sides up. This shouldn't be an issue, but who knows. Next step, I guess: tomorrow I'll pull the drums and have them turned at the local garage. I'll also hook up a runout gauge to the front brakes and check if they are in spec. As I said, they made noise since new. Were they warped out of the box? Maybe I can shim them. Hrmph.
Edited by SameGuy
Sounds like you may have some corrosion between the hub and rotor. Pull the rotor off and make sure the entire hub is free of corrosion, especially the part that goes through the rotor, although, I guess you already tried this.On Friday I spent 5 hours cleaning, polishing and waxing my summer wheels inside and out. Managed to get a touch of heat stroke doing it to. :(But man, do they look good, and after driving all weekend, there is no brake dust on the front wheels at all!!!!! (thanks in part to the EBC Redstuff pads and new rotors I installed a couple weeks ago) Edited by MightyMouseTech
Slotted (Turbo Groove) rotors? No noise?
Yes, I made sure they were were clean the first time I installed them. Second-guessing myself, I used a polishing wheel on my air grinder yesterday and made sure there was nothing there, on either the hub or the rotor. I'm quite convinced it's in the front, but maybe (if I'm lucky) it is from the rear, from one of the stuck brakes situations this winter; having cleaned them out.... I dunno. :confused:
Local garages are closed today so I'm not pulling the drums. When my neighbour gets home later I'll borrow his runout gauge for the front.
Edited by SameGuy
Didn't notice you had slotted rotors. I have always found slotted rotors to make some noise/pulsing. One reason I am not a fan of them, and only use them if I have to. That may/may not be your only source of noise.
Yeah, I know they make a slight bit of regular noise, and the Green Stuff material is also quite noisy (some dust, but not much). But I had no pulsing until I mounted (and carefully, gradually torqued) the pulse alloys for summer. I did that the same day I cleaned the drums, so that's why I can't be sure.Back on topic: today I removed the lone de dion tube cap (the other was lost on a bumpy road somewhere near Hawkesbury), cleaned out the tube ends with a steel wire brush (the gunk in there could be the reason one cap didn't quite get the purchase i thought it did), and installed the new set I got from Fast Eddy.Tomorrow I'm going to take it in to MB and see if they can schedule me for next week, when I'm out of town on vacation. I'll still try to squeeze them for a free loaner -- preferably a B200 -- for my wife to drive around.
  • 4 weeks later...
My wee smartie went to the shop for front and rear alignment to confirm everything is spec following the 25mm lowering. Very minor toe adjustments made. It's "perfect" now!B :sun:
Just perfect for a roadtrip maybe?
swapped my Brabus wheels,17x16 back to my Spikelines. A pothole bent my rear Brabus. The Spikelines are definitely a cushier ride with TOYO Proxes 195/45 16 front and 225/40 16 rears
Edited by SCHMART
Changed the oil and filter. My knowledge and experience at how to work on cars is about the same as how to work on nuclear weapons, so it was a bit of a gongshow. On the plus side, my car didn't explode. (*fingers crossed*)
I much prefer the spikelines!
B :senile:
Washed her lovingly by hand at the self-service carwash bay. They have a nice new accessory -- a hand-held, high-power blower. She sparkles.
How about a nice picture Gordon?Love the color!
Last Thur night on the way to work, it lost all power, no eng light, no smoke, just no power. 40-50km is all it would do. Checked the scangauge, no codes. Pulled it apart and went right after the Turbo to see if the waste gate was stuck or what. After pulling the intake boot off, found it had ate itself pretty good! Yanked it out and picked up a new one at Oakville MB (Cool$1K) Man!!Put it in and it is back on the road. All in all not counting the drive to get the part, about 4 hrs to change out with rear end back together.I would have much rather had been polishing! :angry: Bill
I downloaded the little girl off her big brothers back after giving her a ride up to Baraboo, Wisconsin.Dennis
  • 3 weeks later...
Today I got the stock speakers replaced with JL C2 600s and I added a Kenwood KAC-8404 amplifier. The sound is much nicer, much more crisp. Not to mention much louder!I had asked the shop to hook up the amp to the subwoofer under the driver's seat, but once they took a look at it they feared that plugging an amp into it would blow it. :huh: Anyone here try to plug an amp into the factory subwoofer?
The factory subwoofer has a built in amp. At least the 450 version does.
Edited by Mike T
I can barely hear the sub on my 451 in the best of conditions. If it does have an amp, maybe it's unplugged! :P
Finally had a chance to adjust the HID headlights after lowering the car. A little more difficult with HIDs because the cutoff is not so sharply defined as with standard lamps. But all done now at last!
How to adjust? Follow Evil's instructions HERE, remembering that the "uptick" pattern is reversed for North American cars!
Bil :sun:
