scwmcan Posted March 5, 2011 Posted March 5, 2011 As a follow up to the problems I caused myself last week I am now getting a p0409 code. I have looked online and see the general code list says it is egr related in circuit a. Is there anything more specific to smarts ( looked on evilution doesn't even list the code there). In any case the car is working better with the grounds properly repaired, though I still have no boost. Tomorrows job is to take everything I did last week off and redo it and make sure everything is on properly. Turbo is spinning up just no boost so either a leak or blockage in the intake I assume. Fun stuff I must say. Quote
smartdriver Posted March 6, 2011 Posted March 6, 2011 (edited) It seems too coincidental that you are getting an EGR fault along with your other problems.The EGR cable has a ground connection (PIN 3). An Ohmmeter check between this pin and the chassis would verify its continuity.I don't know where it is connected to the ECU, but along with your other ground problems, if it were missing it could create an EGR fault. Edited March 6, 2011 by smartdriver Quote
mrtransmission Posted March 6, 2011 Posted March 6, 2011 Hey, if you want I can come and plug in my EGR delete box... Mine kept throwing codes as well, my solenoid was shot. Building the box fixed it right up. Let me know, I still need to pick up my KWP unit from ya. I seem to have lost all my drivers for it, if you could throw those on a CD for me, that'd be great. I've got nothing going on tomorrow, and could run out and give you a hand. Let me know. Quote
scwmcan Posted March 7, 2011 Author Posted March 7, 2011 Okay no more EGR fault after today and I have some boost now, I say some because I am having trouble with getting the lower EGR hose to stay in place on the valve, the "clamp" is not easy to get installed, also it is very difficult to get the hose seated properly, any tips for proper installation that don't involve taking everything apart again? I have done this is the past it just doesn't want to work this time. Thanks in advance. Quote
mrtransmission Posted March 7, 2011 Posted March 7, 2011 The weird clamp on the hose from the IC to the EGR? wax up the o-ring, pre install the spring clamp, and try to get it in as straight as possible. It will fight you, but will pop up and 'click'. Quote
scwmcan Posted March 7, 2011 Author Posted March 7, 2011 The weird clamp on the hose from the IC to the EGR? wax up the o-ring, pre install the spring clamp, and try to get it in as straight as possible. It will fight you, but will pop up and 'click'.So it will click in with the spring clamp pre installed? Duh, I've been trying it the even harder way... Trying to install the clamp after I get the hose up it sounds so much better your way, I may even be able to try that after work today if I feel up to it. Quote
scwmcan Posted March 8, 2011 Author Posted March 8, 2011 (edited) Thanks for the help looks like I might Have got it. Full boost and the hose is staying on, and can't hear any leaks, driving it to work tomorrow so hopefully everything stays together. Edited March 8, 2011 by scwmcan Quote
UGo1st Posted May 24, 2011 Posted May 24, 2011 I'm living this kind of situation with my Smart (Passion 2006). After having cleaned up the EGR valve (which was greatly needed) and inspected the Selonoid, I determined that the selonoid is shot.Anyone knows where we can buy a Smart 450 Pre-2008 EGR Selonoid ? Do I absolutely have to purchase it from MB ?How much should I expect to pay for the part ?Thanks! Quote
Francesco Posted May 24, 2011 Posted May 24, 2011 Contact josblos from this forum or CsQ to see if he's willing to sell his recently-removed EGR (or just the solenoid). I believe he's in Stoneham, so not too far for Canada Post.I'm hoping to have my EGR out this week, but I will be hanging on to it for the time being. Quote
pinhead19 Posted May 25, 2011 Posted May 25, 2011 (edited) The EGR is about $275. (Oh the failing memory) If you don't want an egr anymore: View This Topic Edited May 25, 2011 by pinhead19 Quote
UGo1st Posted May 26, 2011 Posted May 26, 2011 The EGR is about $275. (Oh the failing memory)If you don't want an egr anymore: View This TopicThanks Sameguy & Pinhead for the responses. Quote
