2010 Smart Fortwo Pure. How does the wiring harness get to the engine compartment? I see it disappear under the cup holder /gear selector. I want to fish the mechanical gauges.
I don't think oil pressure values are sent by the system, other than LOW oil pressure, which triggers the light. On the other hand, the OBDII does have coolant temperature in 1 degree increments and you can read that any time you want with a Scangauge. I monitor that, boost and fuel consumption with my Scangauge.Whatever gauge you intend to use must be able to tap into an OBDII system.
Another option is the garmin eco route hd, you need a newer garmin gps but you can get water temperature, throttle position, manifold pressure, air intake temp, engine load and a couple other things that are slipping my mind right now. All and all its a very cool system and I'm very happy with it
