smart142 Posted November 29, 2016 Posted November 29, 2016 The Telegraph. UK By Andrew English, Motoring Correspondent 28 Nov 2016 Can an electric car have too much range? Sounds like a stupid question. After all, this is the age of range anxiety, of ‘running out’, so why elect to risk being stranded at the side of the road, hazard warning lamps gently fading, without even a jerry can for salvation? "It depends what the car is for," reasons Horst Michels, Smart's battery engineer. "Bigger batteries cost more and they are heavier; all bad things in an electric car." Extra battery power also takes more time to charge and if all you want is an urban runabout, would you ever cover more than, say 100 miles? And that is the claimed range of this new, third-generation battery-electric Smart ForTwo. Although to be brutally honest, in a route round Miami's beachfronts with 4kW air conditioning and fan struggling to cool the cabin, the real-world range was more like 75 miles. Smart's first battery car was launched in 2007 as a limited trial of 100 vehicles in London. Modified by Zyteck, these cars had molten-salt 'Zebra' batteries which gave a range of 70 miles. In 2009, the first proper Smart battery electric cars were launched using a Tesla-supplied lithium-ion batteries (Mercedes was a shareholder in Elon Musk's car maker at the time), with an 80-mile range. In 2012 Smart launched what it calls the second generation (everyone else calls third generation) Smart Electric Drive (ED). More power and a better lithium-ion battery increased performance and the range to 87 miles. Each generation has sold more and total Smart ED sales now muster 16,500. It's a measure of success that Mercedes has reused the car's lease-return and swapped-out batteries for a second life in a 13 megawatt electrical storage facility in Lünen, Westphalia which helps balance peak demand and supply for the German electricity grid. So for this fourth (third) generation car, Smart is spreading the electric love around with the same driveline used in the four-door Forfour and the cabriolet. The driveline is titivated with an 81bhp, 118lb ft electric motor and a 17.6kWh, 400-volt lithium-ion battery pack using LG pouch cells with the latest nickel, manganese and cobalt materials technology. After losing money on the ForTwo during its entire production run, Mercedes-Benz joined forces with Renault to develop this third-generation replacement, sharing the rear-engine, rear-drive drivetrains and underpinnings for the gen-third Twingo, ForTwo and ForFour versions. An electric version was always planned, which explains the slightly unnatural height of the petrol-powered models. For the ForTwo, Mercedes wisely elected to keep the 2.69-metre length and it's an attractive little thing as a result. It benefits from a much better resolved front than its predecessors while still clearly related to the inaugural 'Swatch' Smart cars first posited by Swatch founder, Nicholas Hayek 22 years ago. The cabin is much improved, too, though confusingly (since Mercedes-Benz eschews them) it has a touch screen in the centre of the facia. A small pod on top of the dash has analogue dials displaying power flows and the battery's state of charge. The instrument binnacle is a half circle with speed indicated round the perimeter, and at the bottom of the centre display are the heater and air conditioning controls. Considering the fact that electric powertrains usually eat into a car’s interior, you’d expect the tiny Smart to be veritably cramped. But accommodation with generous leg and head room for two passengers and no loss of the (admittedly already small) luggage space. The battery is mounted under the floor and the motor, single-speed transmission, charger, power electronics and the cooling compressor are all mounted together in the back – very unobtrusive. While Smart quickly replaced the first models' front transverse-leaf-spring springing arrangement with MacPherson struts (though it retained the De Dion rear), the suspension was too compromised to work properly and the improvements in this model are therefore very welcome. Not that a 1,040kg two-seater with the wheelbase of a pull-along duck is going to offer the finest in ride quality – the front wheels make a decent fist of bumps but the rear wheels thump over drain covers and expansion joints, and the side-to-side pitching is enough to toss occupants’ heads. Part of this is due to the 140kg extra weight that the electric version carries over the standard Smart. Dynamically it's not a disaster, however, despite over-assisted and low-geared steering. The stability systems quickly knock any attempt to over-drive this car on the head, but the Smart's size, cheeky demeanour and whizzy acceleration make it quite fun to weave in and around Miami's (or London's) bloated SUVs. And you'd never tire of the steering lock, which gives a remarkable turning circle of 6.95 metres – comfortably less than that of a black cab, and comparable to the very nimblest vehicles. Like all electric cars, Smart is brisk away from the traffic lights until performance starts to tail off with the torque, at about 50mph, at which poing there’s still more than enough to keep up with US freeway traffic at 60 to 70mph. There's some creep built into the system, which makes hill starts and manoeuvring more simple and familiar to anyone who’s driven an automatic car. The front disc/rear drum brakes are progressive, especially considering they are combining electricity regeneration with friction retardation to slow you down. Motorway travel is reasonably refined, but you do get a lot of moaning and whirring from the rear-mounted air-cooled motor's fan and the air conditioning pump, which cools both the cabin and the battery. Mercedes has its own way of handling regeneration charging. The car’s radar system can sense upcoming traffic jams and turn those regenerative brakes up a notch, causing them to be more active when you lift off the accelerator. This forces more electricity back into the battery as you coast, simulating the inertia of a conventional car. At other times ‘regen’ braking is negligible and the Smart rolls seemingly forever. Steering-wheel paddles to modulate the amount of regeneration were considered and rejected after trials, which had showed that the public didn't understand or use them. Not that all this it helps very much. Driven gently I'd used 10 per cent of the battery's charge after just six miles, 20 per cent after 13 miles and a quarter at 18.2 miles. At this point I considered turning off the radio to eke out a few more miles of driving. This might be an unashamedly city car, but you'd still want to start every journey with a brimmed battery. And to charge the battery from zero to 80 per cent of its charge takes six hours on a 12-amp household supply, 2.5 hours off a wall box using a 32-amp cooker circuit and 45 minutes on a three-phase, 32-amp fast charger. Recharging costs vary wildly, however. A full charge will cost about £2.11 at household rates, but a lot more at stations out on the open road. All UK cars will come with a 22kWh charger, and half an hour's worth of electricity on a fast charger will put about 10kWh in the battery pack. That's about £1.20's worth of electricity at average UK domestic rates, yet Ecotricity charges £6 to hook up for half an hour at one of its motorway fast chargers. That’s a mark up of 500 per cent. Such are the economics of the new electric car world. First deliveries are in the autumn of next year and while prices aren't officially announced, expect about £21,000, which with a £4,500 Government grant, amounts to about £16,500. That's about £2,000 more than the equivalent petrol-powered Smart. The cabriolet ED will be another £2,000 and the forfour version an additional £500. As a second car and an urban runabout, Smart is just about perfect, but don't go thinking it's a substitute for the family motor. It's more honest and useful than that. THE FACTS Tested: Smart three-door microcar, with three-phase, synchronous AC electric motor powered by a 17.6kWh lithium-ion battery driving the rear wheels. Price/on sale: From about £21,000, which with a Government's £4,500 grant gives a price of about £16,500. On sale spring 2017 with first deliveries in the autumn 2017. Power/torque: 81bhp/118lb ft Top speed: 80mph Range: 100 miles claimed in NEDC cycle, 75 miles observed Acceleration: 0-62mph 12.9sec Energy consumption: 12.9 kWh per 62 miles CO2 emissions: Zero at the wheels VED band: 0 (£0 for first year, £0 thereafter) Verdict: This generation of Smart car is the best yet. It looks good, drives well and the ride, if not the finest is adequate for such a short wheel base. This battery electric version doesn't suffer much from its extra 140kg, it's brisk, fun, and the range if not exceptional, is practical for inner cities. Telegraph rating: Four out of five stars https://www.msn.com/en-ph/money/technology/smart-electric-drive-driven-a-clever-car-with-narrow-appeal/ar-AAkStXH Quote
