can anyone help?
my smart city passion 2003 has one headlight lamp not working, i have taken the front off the car and taken both lights out, I swapped them over and the faulty one worked fine on the other side.
Wiring or relay failures like this happen on these cars.  Best to install an external relay in line with the functional wiring.  The functional headlight wiring will operate the relay coil, 12V from the battery through the relay will power the headlights.  Fuel pumps on the cdi can also benefit from the addition of a relay to remove the excessive draw through the SAM.
http://clubsmartcar.com/index.php?/topic/28124-fuel-pump-upgrade/
  • 3 weeks later...
HI all,
finally had the stalk changed but unfortunately no luck, still have a problem, over the last week prior to changing the stalk all the lamps on the drivers side front light have stopped working!! previously it was just the headlight.
any ideas guys?
its the fuse box thing above your left foot
the headlight wires are in the middle of the brown plug when you lower the fusebox youll see the brown connector on the back of it...undo it and see what you see
just saw the england part..not sure which foot its under if right hand drive model
Edited by LooseLugNuts
  • 3 weeks later...
hi all,
thanks for the assistance, i went to a garage in the end and it is a fault with the smart box!! apparently there is an output when you test the wiring but as soon as you turn the dipped beam on the drivers dipped beam fails.
i think I will just sell the car as i don't want to pay out another £400-£500 on a car that was only worth £1000.00, it's a real shame.
