Haven't posted in this thread for awhile!
Current mileage 167156km, still behind @MikeT
In preparation for my BC trip, major maintenances were required as I've been slacking for the last little while:
- New springs and struts all around with OEM springs and Bilstein struts.
- Found that my rear bump stops were destroyed similar to Mike's
- Added spacers to rear bearing mounts to decrease the negative camber to around -1 degree from the factory -2 degree
- Put in a used turbo (just under 100k): the Chinese turbo that I had on there is finally having issues, 1) over boosting (waste gate diaphragm is leaking), 2) my turbo lag is increasing significantly, 3) the gasket between the body of the turbo and the muffler elbow is leaking pretty bad.
- New tires
- New fuel filter
- New glow plugs
- Flushed coolant
- New Air filter
- Oil service (faithfully Rotella T6 0W40) and MANN oil filter. The canister adapter I had on there just leaks like a bastard, so I removed it and went back to OEM
- Hope to get a new windshield if I can get it in before Thursday!
This winter, the cylinder head will be coming off for a cylinder head rebuild. I've been noticing rougher cold idle and smoke. A few other higher mileage Smarts that I've worked on seem to have the common issue of burnt intake valves. I'm wondering if this has anything to do with higher intake temps with the ECM tune.
  • Like 2
You've been busy....I may see see if you're home second or third week in Sept.   If that's ok.
While you have the head off, check the bore for out of round issues. Mine were so badly warped it took 3 over pistons to correct it. I have one of those oil adapters also but not using it. It wasn't covered in oil until I took it off....lol.  Also check rockers for cracks, I had two with the start of cracks. I also had bad valve seats that required replacing.
I'm only 15K km ahead of you and if you drive a bit more than 12K km a year then you may be catching up!
I wonder if Mercedes still has crate long blocks available. I don't expect to change mine but it in theory should be a lot more economical than a rebuild.
I will be doing a full rebuild (whatever parts I can find) for a friend this fall. According to MB, I can’t even find piston rings now. Will have to hit up @Willys on where to source OEM or aftermarket engine internals.
The 2 that I rebuild the heads for, the engine ran perfect. There was no significant wear to the intake seats nor the exhaust seats and valves. The intake valve edges on the other hand was sharp. I put new rockers, lifters and seals in both rebuilds. When the engine fires up, there was zero smoke!
The one engine even had slight scoring on cylinder 3, but it seems the head made all the differences. Like Willys, I will post pics and make a thread when I do my next rebuild.
  • Like 1
  • 6 months later...
Pulled out of storage and RedPxl fired right up! Starting the new year off at 170,636km.
Installed a new dash cam since the old one stopped working.
I have a rebuilt cylinder head on the bench. Didn’t have the motivation to install it.
  • Like 3
Drove RedPxl to work for the 2nd day now. Great fuel economy! But it’s definitely a huge adjustment in driving style from 350hp awd to 60hp (probably less than that!).
Gas is getting expensive…thinking of getting either a Fiat 500e or a Prius plug in…what do u guys think?
We're keeping the smart and soon getting a M-B GLC 350e PHEV. All of our local driving should be possible on battery power alone but 313 combined HP is available for road trips. Heavy car but comfortable.
We plan to keep all our cars. We will keep the GLK250 for roadtrips and Home Depot runs. The RS will be driven only in the winter. The C1 I’ll probably put it in storage if I can find something more fuel efficient/reliable for daily errands. I can’t bring myself to sell the C1…(even if I wanted to, no one in Truck land AB will appreciate it).
So we put a deposit down for a 2024 Fiat 500e Red Edition (pretty much base model). Hope to pick it up tomorrow, but there’s a freaking snow storm…so probably have to reschedule with the dealership for sometime over the wkend.
The 500e has a rated range of 240km. I plan to use it as a daily (<90km round trip). Should be fairly safe even in the winter. My work place is also going be installing a level 3 charger in the near future.
I currently have a 5.5kw solar system and will be installing a 2kw wind turbine as soon as the snow is gone. So fingers crossed I can drive for free!
Red Pxl will be driven by Alex to work and back whenever the roads are clear. We’re doing to cut down on driving our gas guzzlers (GLK250 and Focus RS), though in AB standard they’re “economic”.
  • Like 3
