Willys Posted December 9, 2018 Posted December 9, 2018 Hi Ladies and Germs.....I have generated the 8 didget radio code off my CH341A chip using the reader and program....so far so good. The next trick is to some how get the code breaker program to get the actual radio safe code from the 8 diget number off the chip. I have tried for days to find a working program....I have spent more time into the days range searching for this program and a buddy has just given up after a 3 1/2 hours stint trying to help me. So, if anyone has this code breaker program or can direct me to an actual operational program or where i can get it, it'll be greatly appreciated...to say the least! I have an old laptop all geared up and ready to receive the extra bugs and viruses etc etc that comes with the program so no worries there. I am so close to getting another problem solved regarding the winter machine.....at this rate it'll be ready for spring...lol. Thanks very much for all help. Quote
tolsen Posted December 9, 2018 Posted December 9, 2018 Kindly post your 8 pairs of hex numbers. Quote
tolsen Posted December 9, 2018 Posted December 9, 2018 3 hours ago, Willys said: 32 3E 06 2C 3D 57 3D 57 1810 1 Quote
tolsen Posted December 9, 2018 Posted December 9, 2018 (edited) Try 5906 if 1810 does not work. Will see if I can find a way to attach the code generator if forum allows. GRUNDIG WKC Series Code Calculator 4.00 by stef_no1.rar Edited December 9, 2018 by tolsen Mistype of code. Quote
Willys Posted December 9, 2018 Author Posted December 9, 2018 Sorry was working in the garage on the winter car, still has the same issue...augh!!!!!!!! The link has timed it'self out says trial version is over...so won't open....???...Hmmmmm...? Quote
tolsen Posted December 9, 2018 Posted December 9, 2018 Womder what is wrong with you. Have you tried the code? Quote
Willys Posted December 9, 2018 Author Posted December 9, 2018 No, I have been dealing with my injectors bleed back testing, then the wife had a serious issue with her car.....she couldn't get the door locks to work correctly....nearly had a meltdown..lol. So I have been pulled away from the radio as it's not even in the dash yet....the codes won't go bad will they? So as long as I have them I can get things organized as I'm told, she comes first so she says! She goes go out to work every day so maybe she's right..? Her door locks don't open when she turns the vehicle off or just the driver's door and not the passenger's and the passenger starts fighting to get out.....so with the wife trying to unlock the car from her side switch and her mother going insane trying to get out immediately...it's driven the wife also insane by the way she described her day.....lol. I'll get to my car again tomorrow....sorry to keep you waiting and thanks for the codes by the way! Quote
JBranquinho Posted June 3, 2019 Posted June 3, 2019 I have a grundig with the serial number MC341631354758 anyone can help me? Quote
stickman007 Posted February 5, 2021 Posted February 5, 2021 You need the hex dump file. S/n cannot generate radio pin. Quote
chitul29 Posted February 5, 2022 Posted February 5, 2022 hello, i need help with my radiocd on a smart 450, i disconnected the radio to try another one, and now its locked, its a grunding cd player MC341621041740 thanks for any help Quote
Willys Posted February 5, 2022 Author Posted February 5, 2022 Hello, welcome to the site.....easiest solution buy an aftermarket radio and install it, far easier imho. UNLESS you demand to keep it stock. IMHO, go over to Evilution.co.uk and pay their lowest donation and research there. It is by far the best technical library of information on SmartCars. The only issue is, there is zero chatting ot asking questions. IF you can't figure it out on your own , contact Kane the owner of the site and ask him if he can help you out. Like i said before, it can be done but it isn't easy. I simply wanted Bluetooth after learning what it meant to have it after not having it. I installed a simple radio using it's own fused power supply and new speaker wiring, simply as not to upset the car's electronics. It worked fine. You can also buy radio bezzles for cheap also...$20 or so off Ebay or such. Hope this helps. Again welcome Quote
stickman007 Posted February 5, 2022 Posted February 5, 2022 If you're able to pull the hex dump file, I can generate the Grundig code. I cannot generate code base on VIN or s/n of the radio. Quote
Woody57 Posted January 5, 2024 Posted January 5, 2024 Hi. Can anyone help find my radio code from these pairs of numbers ? I have spent hours looking for the code generator but failed.the numbers are: A7 B9 93 AB B9 D0 B9 D0 Many Thanks Quote
mas Posted August 4, 2024 Posted August 4, 2024 I called my closest MB dealership service department (must have been a slow day), initially they gave me a generic code, it did not work, called back and they asked for the last 4-6 digits of my VIN, I was on hold for a couple of minutes and they came back with the right code. 1 Quote
BlueJuice Posted January 19 Posted January 19 I have the code for my radio, but the radio keep going back to the ------ screen after i enter it. Any one have the same issue? i have disconnect the battery for some time and put it back on again still nothing. i enter the 4 digits press the smart button. nothing, Tries pressing other buttons other then the smart button to enter still wont come on. Any ideas would be welcome. Quote
mas Posted January 24 Posted January 24 (edited) Do you think the radio is accepting the code? Does the same thing happen if you put in the wrong code? Edited January 24 by mas Quote
