smartalec Posted July 25, 2022 Posted July 25, 2022 Hi I’m looking for fuel pump for 2006 smart for two diesel . Three point can’t find one thanks Mhairi Quote
450ken Posted July 25, 2022 Posted July 25, 2022 How many clicks are on your 06 ? Anybody have any idea how many kms these fuel pumps are good for typically before they fail. Quote
LooseLugNuts Posted July 26, 2022 Posted July 26, 2022 only ones ive seen are just generic pumps you install yourself into your old module.... should be plenty of cheap ones on ebay 1 Quote
smartalec Posted July 26, 2022 Author Posted July 26, 2022 The smart cat dealer in victoria says Have an intermittent electrical faultl in the pump… Quote
LooseLugNuts Posted July 26, 2022 Posted July 26, 2022 fault in car wiring for fuel pump is usually a bad connection on connector N11-5 behind the sam Quote
Willys Posted July 26, 2022 Posted July 26, 2022 Research removing the SAM(fuse box) and opening it up to take a peek at the row of solder joints that are well known to create just this issue. Might be the source of all your problems and an easy fix if you can operate a soldering gun and a solder sucker or have some solder wick wire(easier way to remove old solder) Then just re-solder pin and Bob's your uncle, job done. Again, many many Smart cars have this issue and also the headlight pins have the same issue. The pins get hot and they get a crack around the pin on the board, constant hot and cold causes this "cold solder" issue. You may have to use a magnifying glass or something to be able to see the cracks. But I'll bet money it's a good chance it is it. It costs nothing to take the SAM down and open it up, just some time learning how to do it. Easy really once you have done it once or twice. Good luck and let us know how you make out. 1 Quote
smartalec Posted July 27, 2022 Author Posted July 27, 2022 Thanks very much for the advice and instruction . I wish I was braver about fixing it myself …. Quote
LooseLugNuts Posted July 27, 2022 Posted July 27, 2022 (edited) the fuse box is called a SAM...loosen it and drop it down so you can get to the backside of it....there is a brown 12 pin connector i think its labeled n11-3 or n11-5.....disconnect it and check for damage.....the middle two wires are for low beam headlights and almost always have heat damage.....the fuel pump wire is also a common problem ,,,,i cant remember what number it is but its a couple wires away from the headlights so maybe position number 7 or 8...(just guessing for now) if its damaged you can search the forum for threads about the common relay mod fix for headlights and fuel pump i cant find an exact pinout for that connector but im sure its been posted here somewhere Edited July 27, 2022 by LooseLugNuts Quote
Willys Posted July 27, 2022 Posted July 27, 2022 6 hours ago, smartalec said: Thanks very much for the advice and instruction . I wish I was braver about fixing it myself …. It's just an adult jig saw puzzle.....take pictures before you touch it and after every item you remove or undo. Then once you need to reassemble it, simply reverse the picture path....simple....also do some easy research about each topic you wish to look into, it's all been covered here at one time or another and if not, there's plenty of very helpful people here to give you a helping hand so to speak. Advice wise that is. Most things just need simple hand tools and some torx style tools. Princess Auto has everything you will need cheap! Quote
450ken Posted July 27, 2022 Posted July 27, 2022 Are these fuel pumps still available ? or do you have to make some kind of work around with some other pump ? Quote
Willys Posted July 27, 2022 Posted July 27, 2022 Have you asked a dealership about the pump? OR...... https://www.smart-ersatzteile.com/epages/61935289.sf/de_DE/?ObjectPath=/Shops/61935289/Products/127799450bg It says they are temporarily out of stock.....but .... Quote
LooseLugNuts Posted July 27, 2022 Posted July 27, 2022 plenty of new pumps on ebay....you just take the module apart and swap in the new pump Quote
