Smart4two Posted April 9, 2023 Share Posted April 9, 2023 (edited) Hi; The top 2 lights are flashing on Right Rear Tail light assembly when right turn signal is on. Middle light flashes for left turn on left rear tail light assembly when left turn signal is on. Which side is flashing correctly and what might be causing the problem? Edited April 9, 2023 by Smart4two Quote Link to comment Share on other sites More sharing options...
Mjolinor Posted April 9, 2023 Share Posted April 9, 2023 Bad earth on one of the taillights as a first guess. Quote Link to comment Share on other sites More sharing options...
Willys Posted April 9, 2023 Share Posted April 9, 2023 Take the internal housing apart and check for the dreaded white corrosion etc etc....mine was badly corroded and I had to solder a jump wire onto the tracer or track. Quote Link to comment Share on other sites More sharing options...
Smart4two Posted April 10, 2023 Author Share Posted April 10, 2023 (edited) Bad ground is high possibility. I'll test it with a jumper wire. Did not see any corrosion so maybe just the ground wire has an issue. The tail light bulb sockets look like an engineer from France designed them...! Edited April 10, 2023 by Smart4two Quote Link to comment Share on other sites More sharing options...
Mjolinor Posted April 10, 2023 Share Posted April 10, 2023 Engineer France <<< Oxymoron Quote Link to comment Share on other sites More sharing options...
Leadwing Posted April 12, 2023 Share Posted April 12, 2023 If only one bulb is flashing, the other one may simply be burned out. Quote Link to comment Share on other sites More sharing options...
Smart4two Posted April 13, 2023 Author Share Posted April 13, 2023 14 hours ago, Leadwing said: If only one bulb is flashing, the other one may simply be burned out. Thank you. That is highly likely 2 be the problem and thanks for confirming 2 light are supposed to flash. Quote Link to comment Share on other sites More sharing options...
Smart4two Posted April 25, 2023 Author Share Posted April 25, 2023 Both left turn light are flashing now. It fixed itself....! I never attempted to figure out the problem since one left turn light was working and I did not want to make matters worse by messing around. Quote Link to comment Share on other sites More sharing options...
