6 hours ago, Mjolinor said:
The "chip" in the case of the SAM is a monster. More than 100 pins and not easy to do unless you do a lot of them.
As soon as I saw the chip years ago I decided not to mess with it.....if you have experience with electronics at this scale then by all means go after it, but IF you do not, I highly suggest opening up your SAM and looking at how small each pin is and know the fact you can't just "blob" on a lump of solder using a larger soldering iron and not short out two or more pins while doing so. Again, by all means, if you can do this sort of fine repairs you're a better man than me and rightly so. The cost of replacing your SAM should scare you just a bit, imho.
I wish I could do it and also fully understand how and why all that white smoke stays inside the box...lol. Because I do know how to let it out...lol.
  • 3 years later...
On 5/28/2023 at 8:59 PM, MikeT said:
So by transferring those three components over, they didn't recognize each other? Or they did but the airbag fault is the only remaining problem?
I had a new SAM put in My Canada 1 by the dealer, and they gave me the old one. The only problem with it was a dead fuel lift pump circuit. Makes me wonder if I could reinstall it without issues.....
I'll be keeping int anyway.
Good day your way
Long time owner (purchased our Diesel fortwo 450 brand new 2005 in Saskatchewan)
We have recently been struggling with what I've assumed for now is a fuel issue.  Would you mind sharing a little clarity of the "fuel lift pump" I have not come across any data on this are we talking about fuel pump?
Odd double click Please ignore
Edited by frankbonatelli
Accidental post
2 hours ago, frankbonatelli said:
Good day your way
Fuel lift pump = the in-tank pump that supplies fuel to the high pressure pump driven by the camshaft. The N11-3 plug has its feed running through it and any heat damage on that pin (or the low beam pins) means you need to install external relays in those circuits before the circuit goes completely dead.
The two melted ones in the centre are the low beams and the one third from the right is the fuel lift pump. I replaced this connector.
This is the SAM that was changed and I have in reserve now, with a melted fuel lift pump pin on the N11-3 connector.
This is the second SAM, where the two low beam circuit pins show heat damage. This one was recoverable and a new brown plug took care of the problem, combined with the mounting of external relays for the low beam circuits in order to take the amperage out of the SAM.
Edited by MikeT
  • Like 2
