OK, now undo those 8 torx bolts and clean between these two parts. I'll bet that tube is plugged or the entire cavity.   Mine was a clean running engine when i first started driving it so to speak so i thought...? Then when taking the engine apart i saw how dirty a diesel can get!!!
IF that drain is plugged then that may be where your oil is coming from as it can't get back into the sump before being sucked in.
Link to comment
