Sydney Posted May 7, 2024 Posted May 7, 2024 Hi everyone, I am looking for the torque settings for the flywheel to crank and the clutch plate to flywheel. Thanks. Quote
Willys Posted May 7, 2024 Posted May 7, 2024 103 ft/lbs plus 90 degrees flywheel to crank clutch module to drive plate bolts (3x) 15ft/lb plus 90 degrees plus 10 degrees bolt holding drive plate to the other end of crankshaft 45mn plus 90 degrees. 1 Quote
