David466 Posted August 22, 2024 Share Posted August 22, 2024 Hello looking for some advice/help I have purchased a 2017 453 for two needing a new engine as engine had failed due to lack of service I have installed a second hand engine out of a running car but I’m getting a p001192 code for cam timing that wong clear car will crank for a few seconds but that is all Iv checked fuel pump relay it works but there is no earth which is switched on by the ecu as far as I can see it should still run with this code but it dose not hopefully someone will have the answer on here many thanks Quote Link to comment Share on other sites More sharing options...
