Had a friend's smart that's leaking oil at the front crank seal. I did not have any "proper" seal driver - didn't even have a socket big enough to do the job. It was also a tight spot with the rear spring in the way. So, I 3D printed a seal driver.
Cracked the driver as I was low on time and 3D printed with only 30% infill. But it worked beautifully. With the seal driver on, I can now also brake clean the area without any contamination fall in. I will need to make some adjustments to the measurements. If anybody is interested in the file, sent me a pm.
  • Like 3
