Toxophilite Posted August 13, 2025 Author Posted August 13, 2025 DId you mean actual white smoke..magic smoke is an electronics joke. My car makes lots of black/brown smoke I did borrow a diesel compression tester with some adapters. However reading on the evilution site has me wary of trying to remove the glowplugs, though they offer a a method. Perhaps I will try anyway and if by some wretched chance I break one off, That can be my sign to move on Quote
Willys Posted August 14, 2025 Posted August 14, 2025 IF you can get some heat into the engine do it before attacking the glow plugs, but if not a solid 10mm deep socket and careful pressure should release them. Do it like a tap and out a bit then back in to try and keep the fine threads of the plugs intact. Quote
smartninja Posted December 11, 2025 Posted December 11, 2025 Just wondering what happened with your engine ? I feel you went into a rabbit hole with the injector 1 Quote
